09-02-2011, 09:24 PM | #1 |
Pebble Pounder Join Date: Sep 2006 Location: charlotte
| battery life with or without lights on?
i was wondering how much less life you are getting with the lights on all the time. im running my same motor and batterys from my last crawler at about the same weight and only made it about 15 min instead of like 25ish do the lights really drain the battery that bad? im putting them on a switch tonight but was wondering if others have noticed this allso the battery was hotter then normal when i took it out. any ideas
09-02-2011, 11:16 PM | #2 |
Quarry Creeper Join Date: Jul 2009 Location: Buffalo area
With what gearing tho? The LED lights are not going to rob you of ten minutes run time. Might not even take ten seconds out. Count your spur and pinion teeth between the two, I believe your answer is there....... for both questions |
09-03-2011, 12:37 AM | #3 |
i was running 12 an87 or 11 87 im not sure now im running the stock 20 an 84 is that my problem?same motor
09-03-2011, 12:59 AM | #4 |
In a word, YES You went from 55.77 (12/87) to 30-32ish ratio Sorry I cant be more specific, but I am looking up the Wraith stock ratio as I type/edit Maybe YOU could look in your manual and tell me? I think it comes with an 80t spur......... AX30665 so it all comes down to your pinion gear Last edited by cogfounder; 09-03-2011 at 01:13 AM. |
09-03-2011, 01:05 AM | #5 |
would it be ok if i just changed back to a 12 on the motor and stayed with a 84 or should i go 90 my 87 is pretty chewed will i even notice between 84 an 90 from my old 87. the 20 was cool cause i could drift lol but not worth my stuff getting hot and not lasting that long i like to run it for hours thanks for all your help im getting there this is what im dealing with it needs to hit the trails all day and not have issues |
09-03-2011, 01:29 AM | #6 |
YES, pinion down in tooth count. (motor gear) You will loose some top-end speed, but gain crawling torque, and things will run longer and cooler. But with that chewed up spur comment I wonder if you have your gear-gap set correctly??? Set it too tight, and things bind and heat up, too loose and the gear gets "chewed up" . Last edited by cogfounder; 09-03-2011 at 01:33 AM. |
09-03-2011, 01:35 AM | #7 |
Nice looking rig too BTW But not much more than an 87 tooth spur is going to fit in any Axial rig, (SCX or AX type) starts to hit the drive shaft, not to mention it has to still fit inside the new spur gear cover.... to over simplify the issue Last edited by cogfounder; 09-03-2011 at 01:43 AM. |
09-03-2011, 02:25 AM | #8 |
ya the 90 hit my mip so i just changed back to the new 12 and old 87 it had been in there for years im gonna get a new one tomarrow its like warped and the chewed up part is because the allen was rubing at one time but its all good now just a little whiny a new 87 will fix that today when i was testing it was so quite with new gears i hooked the lights back up i will let you know what happens. thanks for all your help go rccrawler fun times fun people. im glade you like not too many people are painting their cages its worth it |
09-03-2011, 10:32 AM | #9 |
ok so ran it today and it lasted about 5min then acted like dead battery put new battery in lasted for about 20 acted like dead battery tried 3 diferent batterys all full charged and nothing no steering no gas an not even a light on the esc, so i took the hood off got to the light plug and just unpluged it that took about ten mins when i was don with all that i checked the esc cause it was pretty hot feeling and it felt fine so i put a nother battery in and it worked for for three batterys back to back to back about hour and a half and never got that hot anymore and my batterys lasted just as long as allways WTF i have front and rear steer. with the lights hooked up it gets hot and shuts down like dead battery with lights unpluged it runs great all day long. what is the cure can anyone help me i would like to use my lights
09-03-2011, 12:44 PM | #10 |
Might have a bad light board. Hook them up to their own battery I guess. You can get a 4AA battery case at radio shack and a switch to wire in too. Might want to use rechargables in it so your not buying regular ones all the time. Its a bandaid fix but will work and take your main battry out of the picture to get back your run times. Should maybe get in touch with Axial too. They may replace the board for you, but you will probably have to send them your old one first. |
09-03-2011, 12:51 PM | #11 |
Pebble Pounder Join Date: Mar 2009 Location: Regina, Saskatchewan
As others have said, no way your lights are going to draw 10 minutes of power from your battery. You're talking a few milli-amps and hour per lamp. Gearing, motor, overall weight will have a far bigger effect on your battery life than a half dozen low draw LED's
09-03-2011, 04:08 PM | #12 |
what about adding a bec? maybe the lights are just pushing it enough to shut down the stock one in the esc or am i dead wrong with that
