09-03-2011, 04:17 PM | #1 |
Rock Stacker Join Date: Jun 2011 Location: Coquitlam
| 550 can 21T, will it burn out the ESC?
as the title goes, can i throw one of these traxxas pups in my truck with out concern? runnin a 2s 5000mah
09-04-2011, 11:29 AM | #2 |
Rock Stacker Join Date: Aug 2011 Location: U.S. Army Germany
Yeah it will work, but I know that some 550 can motors require you to mod the transmission mount because the can is a bit to long, you have to move it forward to get it to fit. Some one on here did it with a tekin motor, maybe you can find their thread or they will read this and post a link.
09-04-2011, 12:09 PM | #3 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
hmmmm that sounds like a plan. the e maxx 21 is quite a torquee unit. will be sure to give us an update, will be watching this one !
09-04-2011, 01:33 PM | #4 | |
Rock Crawler Join Date: Jul 2009 Location: greeley
Using that exact motor until my Brood comes. He's winding a 19 turn for me. Used the stock speed control for about a week, never burnt up. Didn't grind or move nothin. A little slower though. | |
09-04-2011, 02:29 PM | #5 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I just put a 21t Titan in my Wraith. With gearing of 20/87, I had to do a bit of grinding. It was minimal to clearance the motor on two of the side screws (skidplate screw bosses) and a bit on the link mount.
09-04-2011, 03:41 PM | #6 |
sounds pretty good, i have no problem doin some surface removal if need be. What other options would be good on the stock ESC, i want more torque top end is fine not too often i have it full rip for a stretch on the trail.
09-04-2011, 10:41 PM | #7 |
Pebble Pounder Join Date: Jun 2010 Location: Gresham
It will fit, you have to dremel down the lower link mount a little and the shaft on the titan 21t is too lonc so the cover wont fit. I cut off about 5mm off the shaft so the cover fit. I am running more of a crawling rig with an old waterprofed mamba max on 3s with 87/21 gearing. its a little slower than stock but it has gobs of torque, enough to twizzler 2 sets of stock drivelines. needless to say i run my slipper a little looser untill i can get some rc4wd punisher drivelines. |
09-05-2011, 03:26 PM | #8 |
Nicely done, yeah i packed my drive shfts with some aluminium tube to it cant collapse... so far so good. I had twisted 2 sets pf em on the stock motor lol. Ill be grabbing the 21t next week!
09-05-2011, 04:40 PM | #9 |
I put solid rod in mine so they wont crush but they still twist. |
