09-04-2011, 03:00 PM | #1 |
Pebble Pounder Join Date: Aug 2007 Location: F-M
| Hitec 7955tg servo on stock wraith question
Can i run the hitec 7955tg 333 oz in servo on an otherwise stock wraith without using a bec? thanks for any help
09-04-2011, 03:07 PM | #2 | |
Rock Stacker Join Date: Aug 2011 Location: U.S. Army Germany
I'm running a mamba max pro which has a good internal BEC, with two associated DS1015 high torque servos, (front and rear) which are around 300 oz in and I still need an external BEC because the servos draw so much current. Last edited by Slowsteve; 09-04-2011 at 03:14 PM. | |
09-04-2011, 03:24 PM | #3 |
will the 10 amp castle bec do the job in this situation? how do they hook up? sorry ive never used one before.
09-04-2011, 03:25 PM | #4 |
I wanna be Dave Join Date: Jul 2008 Location: Southwestern, Ohio
09-04-2011, 03:27 PM | #5 |
09-04-2011, 03:43 PM | #6 |
thanks slowsteve appreesh the help. as for the search button its easier just to ask someone who knows than to sift through 40 pages to find what i want sometimes.
09-04-2011, 10:45 PM | #7 | |
Rock Crawler Join Date: May 2010 Location: Albuquerque
courtesy of Thomas @ RMDW this method skips the rx all together to provide battery voltage straight to the servo . . . the only thing the rx does is send a signal voltage to the servo to make it go back and fourth. it isnt trying to power the servo. and a really easy way of wiring it this way would be to use the paradox BEC jack. . . . which is a jumper harness that plugs to your servo, bec and a leader to send signal wire to your rx. its plug and play and really easy to use, plus it still allows for programming of your ccbec later on. hope this helps Last edited by Chappy4o; 09-04-2011 at 10:48 PM. | |
09-04-2011, 10:53 PM | #8 |
Pebble Pounder Join Date: Jun 2010 Location: Gresham
A r/x capacitor will bandaid it but wont replace a ccbec. The sidewinder(pretty much all castle esc's) does not do well with high power servos.
09-05-2011, 05:47 AM | #9 | |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
I just spliced my castle bec into the red and black battery wires and plugged the other end into the bind hole on the receiver. Works awesome. Sent from my highly abused iPhone using Tapatalk | |
09-05-2011, 01:52 PM | #10 |
Great info guys, hopefully this helps more noobs than just myself....wraith arrives tomorrow and I can't freakin wait to get my hands on it, my gf is going to be soo jealous hahaha |
10-08-2011, 07:48 AM | #11 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
Im gathering some parts together b-4 i pick up my wraith kit, my lhs sold me a 7955tg for $105 Does the aluminum servo horn that comes with it work? or is a longer one needed for more throw?
10-08-2011, 07:59 AM | #12 | |
Quarry Creeper Join Date: Oct 2008 Location: Folsom
Will it work..... Yes... its a matter of personal preference... some of us like the style of a servo horn to be a clamp style..... you should definitely go with alum.... That being said there are many companys that offer alum servo horns.... Robitronics, racers edge and many more to choose from... Sorry this prob isnt much help... | |
10-08-2011, 11:12 AM | #13 |
Rock Crawler Join Date: Nov 2009 Location: poteau
i cant say for sure if the servo you have will work WITHOUT a bec, but i'm running a jr z9000t servo on mine. it works fine WITHOUT a bec. i'm only running 2s lipo's tho. i know if you go 3s you NEED a bec. i have a bec to install, but i'm waiting till i switch everything over to deans connectors. also i'm probably going with a HH brxl esc, and with that esc i shouldn't need an external bec. |
10-08-2011, 11:13 AM | #14 |
Rock Crawler Join Date: Jan 2010 Location: In the office, working on RC Projects!
10-08-2011, 11:45 AM | #15 |
Pebble Pounder Join Date: Aug 2008 Location: Wichita Falls
I run the HS-5955TG, the model that the 7955 replaced using the method above for the time being. I ran it with all stock steering and now have the VP tie rods and drag link. It has enough torque that I know my c-hubs or knuckles will break but I'm fine with that since my plans are to replace them anyways. you can use the 10 amp BEC for 1 servo no problem, maybe even 2 servos. If you run a 3rd servo you'd need a 2nd 10 amp or a BEC Pro (The route I took)
10-14-2011, 12:17 AM | #16 |
Pebble Pounder Join Date: Sep 2011 Location: Western Colorado
Anyone know the performance differences between wiring the bec directly to the servo as castles site diagrams or to the esc as axials diagrams?
10-14-2011, 05:13 AM | #17 |
10-14-2011, 07:44 AM | #18 |
Sorry, meant rx Is this important on the "whimpier" rx that comes stock? All I'm wanting to do is add a 7950th to the original elcetronics setup (plus bec) and use 2s lipo. Would I still need to protect the rx with just this change? |
10-14-2011, 08:02 AM | #19 |
| As of right now I have my BEC Pro powering my RX and 1 servo. When I setup my rear steer and dig I will be wiring direct so I don't have an overload of current draw through my RX. So in my opinion and research I think it is ok if your just powering the 1 servo, but if you add more I'd do the direct method. And remember to remove the red wire coming from your ESC!
10-14-2011, 10:38 AM | #20 |
The only reason to wire straight to servo as opposed to going to rx, is for a higher voltage servo (program bec for higher voltage) and skipping the rx if it can't handle said voltage. Other than that, plugging into the rx at standard voltage will give your system the amperage it needs for a high amp draw servo works well
