09-16-2011, 12:22 PM | #1 |
Rock Crawler Join Date: Nov 2009 Location: poteau
| drag brake??
i know the box says the stock esc has a drag brake, but mine sure doesn't seem like it. is there a way to program or set up the drag brake WITHOUT a castle link? if not, then i guess i'm ordering more stuff!
09-16-2011, 12:46 PM | #2 |
Pebble Pounder Join Date: Dec 2010 Location: UK
No, you need to connect it to a pc. The castle programming card works but only as a pc link. Card itself can't program the esc. On the menu you can turn the drag brake up to 100%. But, on the proper Castle sv2 esc you can turn it up to full 'crawler mode' which is 213%. So you can make it far better than stock (50% I think) but you won't get a full crawler brake from the stock esc. Hope that helps. |
09-16-2011, 01:28 PM | #3 |
| Just recalibrate your controller. That is likely the problem. The instructions are on the Axial website under the ESC. It's simple to do.
09-16-2011, 01:49 PM | #4 |
Newbie Join Date: Jun 2011 Location: Houston, TX (Tomball)
i thought i read somewhere on the "destructions" that you can program the esc by following a series of beeps and led colors? (or is that on my BR-XL)
09-16-2011, 03:56 PM | #5 |
Brake brake isn't going to be too noticeable with the stock motor.
09-16-2011, 03:58 PM | #6 |
Newbie Join Date: Aug 2011 Location: Chicago area
Yes you can program the AE-2 ESC without a castlelink. Instructions are here: http://axialracing.com/wordpress/2011/08/18/axial-ae-2-esc-set-up-and-programming/ |
09-16-2011, 06:03 PM | #7 |
Now all I have to do is remember to make it a clickable link. http://axialracing.com/wordpress/201...d-programming/ |
09-16-2011, 07:35 PM | #8 |
Pebble Pounder Join Date: Aug 2007 Location: F-M
| says default drag brake setting is 100% so im guessing thats as much as you get without a pc link. not sure if you can program stock esc over 100% drag brake with the castle link. |
