09-17-2011, 05:56 PM | #1 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
| Axials New Links....?
I dont know how many of you still go to the main RCC page but I stop in there from time to time to see whats new. They have up there that Axial released new aluminum links for the Wraith like the ones that comes in the kit version. Heres where I am confused, They show straight links however every other company has made some sort of bent/curved link for the Wraith. Will straight links work? Do you have to run some wierd bent rod ends?
09-17-2011, 06:20 PM | #2 |
Pebble Pounder Join Date: Aug 2011 Location: schererville
i made my own straight links out of revo ends and aluminum sleeve, with thread rod inserts. all lower links straight, didnt do upers yet. see no reason for the bent ones, straights work fine.
09-17-2011, 06:25 PM | #3 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
I asked this question too in another section and AXIAL themselfs said that straight uppers wouldnt work because it would hit the drive shafts? not sure on why they are selling straight links for it... well here is your anwser, since nobody likes to read The Threaded Aluminum Links are the Factory Axial option parts to replace plastic lower arms on the Wraith RTR and are a perfect upgrade for the RTR enthusiast who seek higher impact load resistance and or upgraded motors that are putting more stress on the suspension. These Aluminum Links will not flex under heavy power transfer for true straight-line performance. Installing the Threaded Aluminum Links will require the use of the following items to install: AX80018 (plastic balls) -or- AXA1331 Steel Flange Ball / AX80057 Link Ends / AXA187 Set Screws. most likely you can upgrade the uppers if you buy the right bent links.. Last edited by Twiztid Metal; 09-17-2011 at 06:29 PM. |
09-17-2011, 10:51 PM | #4 |
Rock Crawler Join Date: May 2010 Location: Albuquerque
| 'nuff said . . . custom aluminum links with axial 45* rod ends . . . . . works perfect . . . . the reason for the curvy links is IMHO for form rather than function and so that straight rod ends can be used . . . i dont see why it would make a difference . . . . but they sure look cool |
09-18-2011, 05:54 AM | #5 | ||
| The Question: Quote:
The Results: Quote:
http://www.rccrawler.com/forum/showt...60#post3121560 | ||
09-18-2011, 07:30 AM | #6 |
Pebble Pounder Join Date: May 2011 Location: Port st. lucie
As far as looks go. I really like the Vanquish links. They appear to be the same diameter as the tube chassis. Also being bent, adds alot of style. Plus you can turn the lower link's peak of the bend, either down or out. Turned out, allows for a little more flexability. However, If you are running the MIP AX10 shafts. The bend turned down better protects the cup of the shaft.
09-18-2011, 09:15 AM | #7 |
Pebble Pounder Join Date: Jun 2010 Location: Gresham
I have strait links on mine as well 98mm with bent ends at the axles and strait end at the tranny and they work great. |
09-18-2011, 10:43 AM | #8 |
Quarry Creeper Join Date: Jul 2004 Location: Arkie-Saw
Problem with the Axial bent rodends is that they are weak. Broke them quite often on my first comp rig. Going with the straight rodends from a Revo or something similar wont rip apart. And the way I treat my Wraith I know they wouldnt last.
09-19-2011, 11:06 PM | #9 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Nice stuff in here...answered a few questions I had Thanks. |
09-20-2011, 07:29 AM | #10 | |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
I'm curious about the endlinks that will be used in the new kit Wraith. Hopefully they're stronger since the links are 7mm vs. 5mm (IIRC). If so, I'll try them out. | |
09-20-2011, 11:23 AM | #11 |
Quarry Creeper Join Date: Jan 2011 Location: Detroit and Denver
I installed some green axial links top and bottom on my wraith but the 3mm studs and ends are just weak and kept breaking on me. My buddy eggoz tapped and rethreaded my links to accept 4mm studs and revo ends and this thing is bulletproof ..... just my 2¢ Sent from my Nexus S 4G using Tapatalk |
09-20-2011, 02:13 PM | #12 | |
09-20-2011, 03:19 PM | #13 |
it made the wheelbase a little longer but like I said, they are pretty stout. Sent from my Nexus S 4G using Tapatalk |
09-20-2011, 09:55 PM | #14 | |
09-21-2011, 07:03 AM | #15 |
