09-18-2011, 06:35 PM | #1 |
Pebble Pounder Join Date: Mar 2006 Location: Paradise
| What parts interchange between Ax10/scx10 axles and wraith
I want to put some wraith axles in my scx10, and i was wondering what parts intherchange. Can I reuse my gears, bearings, and hex's and stuff? |
09-18-2011, 06:38 PM | #2 |
Pebble Pounder Join Date: Aug 2008 Location: Wichita Falls
All in the beginners guide.. Below are what works with the Wraith, so reverse should be the same. Crossover Parts from AX10-SCX10 Axle Gears - AX10/SCX10 Trans Gears - AX10/SCX10 except for one piece final gears. The Wraith uses an extended output shaft on the rear. Trans Case - Wraith only (the front half of the transmission case is different then the AX/SCX as well. Knuckles - XR10 (stock geometry only, VP XR knuckles will not work with the stock wheels) C-hubs - XR10 Rear Lockouts - Wraith only Axle shafts - Wraith only Upper links - XR10 Uppers or AX10 Bent Lowers Lower links - Possibly XR10 with certain rod ends Steering linkage - Wraith only Driveshafts - AX10 driveshafts will work but the Wraith comes with a CVD style shaft Shocks - Fairly universal |
09-18-2011, 09:00 PM | #3 | |
So I have a complete scx10, and I happen to have some stock XR10 C's and knuckles, So I am thinking all I need to buy is: housings diff covers (come with link mounts) axle shafts rear lockouts Is that it? I found everything on ckrc except the front universals, where can I buy those? | |
01-02-2017, 03:31 PM | #4 | |
Newbie Join Date: Dec 2016 Location: akron
| Re: What parts interchange between Ax10/scx10 axles and wraith Quote:
Sent from my LGMS631 using Tapatalk | |
01-02-2017, 03:40 PM | #5 |
Yes the diff cup, locker and gears are the same between them.
01-02-2017, 06:00 PM | #6 |
Tyvm....just ordered the housings,knuckles chubs&axle shafts Sent from my LGMS631 using Tapatalk |
01-02-2017, 06:17 PM | #7 |
You'll also need 2 of these these parts trees. You'll also need a pair of link mounts and a set of lock outs |
01-02-2017, 06:24 PM | #8 |
Got housings,axles,c hubs,knuckles,bearings,diffcovers and lil bearing caps,upper and lower ink mounts and poison spyder wraith link set i got a get a wraith skid plate yet.i got a scx10 frame and axles for parts lol an a proline 1/8 scale Silverado body.....2.2s or 3.8 crawler tires are up next Sent from my LGMS631 using Tapatalk |
01-02-2017, 06:36 PM | #9 |
You don't need the wraith skid. I've built a couple wronchos with just scx skid plates.
01-02-2017, 06:47 PM | #10 |
Really?sweet...i got the wraith links for the wheel base and axles for the track width this is working out awesome Sent from my LGMS631 using Tapatalk |
