09-30-2011, 09:25 AM | #1 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
| Hot Racing differential locker issue
So got my Wraith upgrade care package from rpp yesterday. One of the things I ordered was the HR differential locker: http://www.rpphobby.com/product_p/hotscp125r.htm I've used this before in AX10 axles with no issues. Not so with the Wraith. Putting it in the rear axle with underdrive gears, I'm getting a lot of binding. Part of it was due to the screws that come with the locker (replaced with the stock Axial ones and it got rid of the rubbing), but still getting too much binding. Anyone else using these lockers running into this issue? I know I can solve it by a little grinding down of the locker or case, but maybe I just got a bum locker? On a related point, what upgraded lockers are people using successfully in their Wraith axles? Falsenfests? Others? |
09-30-2011, 09:31 AM | #2 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
hmmm...those are what im gonna use as well.. any pics? |
09-30-2011, 09:55 AM | #3 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
I tried to start assembling my Kit last might and ran into a similar problem with my stock gears and locker. The short side shaft doesn't seat far enough for the straight axle end caps to seat all of the way (about 1/16" gap) which would cause some serious binding if you forced it together. If this is the same problem you are having it might not be the locker but the back side of the ring gear recess not being deep enough, or it could be that the flange on the short straight axle was machined too close to the end of the shaft not allowing it to seat far enough. I'll try and look at it again today after work and start swapping parts to see if I can get something to work.
09-30-2011, 10:01 AM | #4 |
Nope, thought of that as I ran into that issue with super 300s in Axial axles (slight bit of grinding on the locker side of them fixed it). The binding happens even with the inner axles out. With the stock locker/diff cup and underdrive gears, no binding at all (although I've always found the mesh between the ring and pinion on underdrive gears to be less smooth than stock ratio). The locker with bearings goes in to the axle, but it's a tight fit, doesn't just drop in. So I definitely think something is off with the tolerance on this locker. I'll try this one out in an AX10 axle to see if I get the same binding. If so, probably the locker. If not, then there's very slight design differences between Wraith and AX10 casings around the differential. Anyone tried the highland crawler lockers in their Wraith? |
09-30-2011, 10:11 AM | #5 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Chris, I had the exact same issues. I am using the HR Bearing race seats too. The best way to deal with this is either use the Axial screws that come with the lockers, Or to rotate the spool several times to leave a small nick in it. and take a hand file and file a small groove. They are very strong and work nicely. Its just the head on the screw is too large and sticks out past the face. But everything with the bearings seat excellent in the case with no other binding or tolerance issues. Last edited by team3six; 09-30-2011 at 10:13 AM. |
09-30-2011, 10:18 AM | #6 |
Rock Crawler Join Date: Sep 2007 Location: Petaluma
i had falsenfest lockers but didnt like the set screw idea. i switched to rcp stainless steel lockers,which i use for my scx10 and the work perfect for my wraith. a little bit more rolling mass,but the weight is in the right place
09-30-2011, 02:00 PM | #7 | |
Rock Crawler Join Date: Jan 2007 Location: UK
Rear axle short shaft issue? | |
09-30-2011, 02:36 PM | #8 | |
09-30-2011, 03:04 PM | #9 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
I just received my Highland crawlers lockers last night. Unfortunalty they are not installed yet. If I get them installed before you solve this dilema I will post up my results
09-30-2011, 03:55 PM | #10 |
Newbie Join Date: Sep 2011 Location: DFW
i've just had to keep tightening mine. they come loose every few days. i'm hoping when i upgrade all that stuff this problem goes away.
09-30-2011, 04:12 PM | #11 | ||
The RCP lockers look good as well, but $40 for shipping | ||
09-30-2011, 04:19 PM | #12 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
I don't have a wraith but I have had good luck with the RCP lockers. http://rcpcrawlers.com/product.php?p...0&cat=0&page=1 |
09-30-2011, 04:33 PM | #13 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
After many "iron cross" faliures, I took a steel Maximizer locker and drilled it for the 3 x 22mm pin that came with old stock axial aluminum locker. Of course, the lockers are as scarce bonus lines'. As for the OP's problem, are you using a gasket between the locker and ring gear? If so, have you tried without? |
09-30-2011, 05:03 PM | #14 | ||
It'll get solved one way or another. | ||
10-04-2011, 10:21 PM | #15 |
RCC Addict Join Date: Sep 2009 Location: sacramento
i just installed hrs in front and rear and they went in very easy with no binding at all work great
10-07-2011, 07:13 AM | #16 |
installed my HR steel lockers in the rc4wd axles,no problem. only binding i saw was when i overtightened the bearing cap.. backed off the screw just a smidge,all spun freely. |
10-07-2011, 09:03 AM | #17 |
Chassis & Tubework Vendor Join Date: May 2006 Location: Portland, OR
Here is one more option for you, the XHD no slop locker: http://www.rccrawler.com/forum/axles...p-lockers.html |
10-07-2011, 09:35 AM | #18 |
I wanna be Dave Join Date: Nov 2008 Location: Too old to care
10-07-2011, 10:09 AM | #19 |
10-07-2011, 10:14 AM | #20 |
Quarry Creeper Join Date: Aug 2005 Location: newport
that's a RC4WD silver housing, they come n black too
