10-03-2011, 08:21 PM | #1 |
Quarry Creeper Join Date: May 2010 Location: Los Angeles
| I hate seeing early broncos chopped up. So I chopped up my Wraith. Just a bit more trimming and then heating the cage to shape it to fit the back and it'll be perfect. Full interior caged Early Bronco! I'm also swapping out every screw for RCScrewz stainless. R35s on Mayhem wheels with wide offset so I shouldnt have to narrow the body. Got full STRC Gunmetal knuckles, c-hubson the way, an aluminum servo horn. If this turns out as good as I think it may I'll spring for every hopup and keep this sucker for a long time. I think it needs a tail spare tire, full lighting, and a front bumper of some kind. I've always wanted a CR/CC-01 Bronco/Unimog but knew that they didn't perform worth a damn. I shortened an SCX10 for a Unimog and it worked well, but the short wheelbase performed horribly when climbing over rocks. Backflip central, sure is fun as a trail rig though! I just can't bring myself to spend so much money on the CR-01 or CC-01 :( The junfac lizard chassis was sexy though Ideas and input welcome! Edit: All finished and buttoned up. No rubbing so far after a quick run around the yard and up the curbs outside. Last edited by daign; 10-25-2011 at 10:21 PM. |
10-03-2011, 09:18 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Take a deep breath then lower the suspension and trim the body as needed.
10-03-2011, 09:56 PM | #3 |
Rock Stacker Join Date: Oct 2009 Location: port orchard
so is this a full size 1/10 th body or a mrc body. i like the idea, but ya it needs to be lower c.o.g. |
10-05-2011, 07:03 AM | #4 |
Rock Crawler Join Date: Aug 2005 Location: Illinois
How about some body off shots to show exactly what you did to the frame? Are you leaving it a full body or chopping it? J |
10-05-2011, 04:11 PM | #5 |
10-05-2011, 04:11 PM | #6 |
10-05-2011, 04:13 PM | #7 |
| Front I only cut off the supports for the V shaped bumper, Then you end up with a perfect shaped cage for the front of the bronco body. Full body. I've always wanted a CR01, never wanted the performance ;)
10-09-2011, 10:57 PM | #8 |
Quarry Creeper Join Date: Sep 2011 Location: Columbus, Ohio USA
You planning on shortening the wb any?
10-11-2011, 08:01 PM | #9 |
| No. Like I said I learned that lesson with my SCX10. All shortening does is cause flipping on steep inclines and climbing rocks. I honestly think the only reason the CR-01 series are only popular because of the bodies and die hard tamiya fans. But they just flip everywhere. Keeping the axle out front like a one ton. Rear is pretty close. Added some VP steering linkage and gunmetal STRC C-Hubs and Knuckles. May add more of their stuff after I paint the body and see how it all looks. Also did some further cutting in the rear and cut out some battery tray support stuff. I added a 55mm link between the shock towers to tie the frame together at the shocks. Its super solid. I have one for the front as well. I left the lower frame tubes for bumper usage later or expansion. I'd like to link them to the shock towers as well. Shell just sitting on the cage, perfect fit really! SHocks and paint next. |
10-12-2011, 01:12 AM | #10 |
RCC Addict Join Date: May 2011 Location: Utah County
cool idea. i was gonna buy a parts tree of the wraith cage to chop up and make an interior cage for my cherokee scx10.
10-13-2011, 01:46 PM | #11 |
Quarry Creeper Join Date: Sep 2011 Location: hemet
it is looking good. one question: will you have body posts like a short course truck or are you going to screw the body on. I am wondering how you are going to access the electrical items like battery and receiver.
10-15-2011, 07:50 AM | #12 |
Quarry Creeper Join Date: Jul 2009 Location: SW Hell
updates?..this opens alot of doors to whats possible with a lil foresight.
10-15-2011, 08:15 AM | #13 |
Rock Stacker Join Date: Sep 2011 Location: Twinsburg
i like the uncut body on the wraith, good job thinkin outside the box
10-15-2011, 12:46 PM | #14 | ||||
Some updates. Just got finished peeling off the outer wrap and scraping off the liquid Mask and paper mask. This is VERY rough. Also mounted the SCX10 shocks. WAY too low. Going back to the stock wraith, or may order something.... The cage came out looking fantastic inside the full body. Servo in way at this height. https://lh4.googleusercontent.com/-mt0nMaAYYlI/TpT0M1ZIaBI/AAAAAAAAFcI/0qZM9aiLCMg/s800/IMG_7630.JPG[/IMG] LOVE this color. Tamiya Anodized Blue. https://lh6.googleusercontent.com/-Q...0/IMG_7638.JPG Battery Access STRC parts. Too much toe out. Last edited by daign; 10-25-2011 at 10:17 PM. | ||||
10-22-2011, 03:18 PM | #15 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
how come your pictures are just black squares with a white dash? did you loose your photo account? like to see what u did. |
10-22-2011, 03:43 PM | #16 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
I can see them, whats wrong with you guys. |
10-25-2011, 10:20 PM | #17 |
All finished and buttoned up. No rubbing so far after a quick run around the yard and up the curbs outside. |
11-13-2011, 07:35 PM | #18 |
~ Got PROPANE ? ~ Join Date: Feb 2009 Location: East-Central
It's monster truck-ish looking to me....reminds me of how all the traxxas and other brand monster trucks look. I dunno....it's probably just me....but I really like for my rigs wheelbases and widths to match as much as possible. That's the thing about the Wraith that I found to be most appealing....the fact that they were trying to make it look pretty scale. To each his own though...and if it works for you that's all that really matters anyways ! I'd like to see some of the pics that show what you did to the cage/chassis though....I'm just curious. But your pics aren't workin for me either.....most of them are just the black square with the white - sign in the middle of em ! ArOn |
