10-04-2011, 08:19 AM | #1 |
| Wraith Steel Tranny Gears?
I was on CKRC in the Wraith hop ups section...they are selling metal AX10 tranny gears for the Wraith tranny. Does this mean that Robinson hardened steel gears fit in the Wraith tranny as well? What parts would I need to order? Or is the Wraith tranny the same thing as a standard Axial AX10/SCX10 tranny? Thanks! |
10-04-2011, 08:23 AM | #2 | |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
Ray. | |
10-04-2011, 08:28 AM | #3 |
Pebble Pounder Join Date: Aug 2011 Location: phoenix (Ahwatukee)
isn't one of the output shafts longer on the wraith though?
10-04-2011, 08:32 AM | #4 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
my steel gears should be here today.. ill snap some pics for ya. |
10-04-2011, 08:36 AM | #5 |
10-04-2011, 10:04 AM | #6 |
Newbie Join Date: Jul 2007 Location: Norway
| yes.. but that dosen`t mather here is the parts: http://www3.towerhobbies.com/cgi-bin...&I=LXWTN3&P=ML http://www3.towerhobbies.com/cgi-bin...?&I=LXWTN2&P=Z |
10-04-2011, 10:16 AM | #7 | ||
I am running that final gear but it is aluminum, there are steel options available. | ||
10-04-2011, 11:40 AM | #8 |
| I retract my statement about the case then. I could of sworn i saw someone saying they were using one.
10-04-2011, 11:41 AM | #9 |
10-04-2011, 11:42 AM | #10 |
10-04-2011, 11:43 AM | #11 |
10-04-2011, 11:48 AM | #12 |
| Worked well for me. I took the trans out though and put the stock unit back in though because I didn't want the dig anymore after running 4WS. I am wondering now though with the low ride height if you could clear it. You would need a damn long driveshaft though...
10-04-2011, 11:57 AM | #13 |
| Yea - i dont see a need for dig anymore now that i got 4WS all dialed in. Would be nice to have an alum case though. Dont' really think purchasing dig just to get the driveshaft to hook up is really worth it..wait.. . And 10-4 on the driveshaft.
10-04-2011, 07:43 PM | #14 | |
10-05-2011, 09:39 AM | #15 | |
If I keep the stock outputs I can just run these Robinson gears. All my Axial trannys are loaded up with these and never had problems! | |
10-05-2011, 09:51 AM | #16 |
Pebble Pounder Join Date: Jun 2010 Location: Gresham
here is a few shots of the RR alum main and steel idler before after |
10-05-2011, 10:03 AM | #17 |
10-05-2011, 10:07 AM | #18 |
06-14-2013, 01:34 PM | #19 |
Newbie Join Date: Jun 2013 Location: tucson
| Re: Wraith Steel Tranny Gears?
Excuse my ignorance but I'm new to this RC crawler thing... do the main and idler gears come only in one tooth configuration? I see every other gear wether it's differential or transmission gears, they come in different tooth numbers to combine them and get different ratios but these two don't, websites don't even mention how many teeth they have, they just say they are "gears" to replace the stock nylon ones. Again, excuse my ignorance but I'm lost... Thanks! |
06-14-2013, 02:03 PM | #20 | |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Re: Wraith Steel Tranny Gears? Quote:
The spur / pinion is important to the motor/ esc/ battery. To low of a ratio will cause overheating issues. Stock wratih ratio is 4:1 (20T Pinion / 80T Spur) I am currently running 6.21:1 (14T P / 87T SP) Finding the ratio your motor / esc / battery likes is the most important 1. The stock motor smokes fast because of the 4:1 ratio. The front & rear ratios can be changed so you can adjust how fast the axles spin. Underdrive gears in the rear make the rear spin slower than the front. Overdrive gears in the front make the front spin faster than the rear. If you underdrive both axles you go slower with more torque & if you overdrive both axles you go faster with less torque. Start with the pinion & spur & aim for 5:1 - 6:1 ratio & test untill you can run 2-3 packs in a row without your motor/esc/battery getting too hot (hotter than you can leave your finger on it for 1-3 seconds) Then look at the axle ring & pinion gears if you want to tweak a bit more. Change slowly & test carefully. I burned up my new HH 35T in 2 packs with a 16T pinion & it runs just right with the 14T. What goal do you want to achieve with new gears? | |
