10-11-2011, 09:04 PM | #1 |
Rock Stacker Join Date: Jun 2011 Location: Coquitlam
| VXL3s esc. Where did u put it
Im havin a hard time deciding where to put my vxl3, i have my battery up front right now and its becoming a pain in tha ass to locate the waterproof box from my slash ..... is there really much benefit having the batt under the hood? or should i revert back to stock locations for easy assembly.... Thanks |
10-11-2011, 09:13 PM | #2 | |
I hated the VXL setup though, only ran it a couple weeks. | |
10-11-2011, 09:36 PM | #3 |
What do you suggest Harley, fried stock esc on 3s and have gone through a couple motors.... drive train is beefy MIP shafts and robinson gears in trans. I wont be crawling i have the xr10 for than just want to thrash some trails with decent power and figured the vxl would be alright.
10-11-2011, 10:00 PM | #4 | |
10-11-2011, 10:23 PM | #5 | |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
10-11-2011, 10:24 PM | #6 | ||||
Quarry Creeper Join Date: Sep 2011 Location: Columbus, Ohio USA
Cheers,
The BEC, LED controller, radio and antenna are in a non-lubricated rubba behind the esc. I made a battery extension cable that runs under the interior, The actual battery plug is in front of the rear axle and I tuck the connector on the opposite side of the driveshaft.
Tonneau cover just velcros to the pack. | ||||
10-11-2011, 10:48 PM | #7 | |
10-12-2011, 06:56 AM | #8 |
10-13-2011, 12:10 AM | #9 |
| Thanks, good to know. Based on that I think I'm going to definitely buy an esc first and get my drag back. I'm happy with the power and I have it geared low enough that it doesn't chug.
02-06-2012, 07:09 PM | #10 |
Rock Crawler Join Date: Nov 2008 Location: Sunny Southwest Florida
| Re: VXL3s esc. Where did u put it
I tossed mine all the way in the rear. I am planning on replacing the VLX3S motor with a sensored 13.5 I am replacing in my race T4.1FT with a new 10.5. You can run sensor wire to the VLX3S ESC there is a cover up front on the bottom the wire plugs into. |
02-06-2012, 07:24 PM | #11 |
Rock Stacker Join Date: Jan 2012 Location: wheatfield
put that speedo in trianing mode on a 3 cell and give it a try. That was the first motor and esc in my wraith, and I kinda miss it. when you set it up in training mode it gets waaaay smoother. yet cuts the speed near 1/2 geared right it works ok on the rocks, not as good as a sensored but not bad. put the 3 cell toit in training mode and it is a blast you got it might as well try it!
