10-15-2011, 03:15 PM | #1 |
Newbie Join Date: Aug 2011 Location: Chicago area
| RC4WD Humvee 2.2 Wheels
Well, after e-mailing RC4WD to see if their 2.2 Humvee beadlock wheels would fit on a stock Wraith, and being told they would, I ordered them. Well, they don't fit. The whole the axle goes thru is too small to fit over the raised center part on the Wraith 12mm hex. So, as I'am new at this, what now? Try to drill them out and hope the whole stays centered? Is there some other Axial 12mm hex to get with a smaller raised center, or no raised center? Is this common with beadlock wheels? |
10-15-2011, 03:33 PM | #2 |
Pebble Pounder Join Date: Dec 2009 Location: ca
You can remove the wraith hexes and grind the center portion of the hex out. This will allow you to use the humvee wheels. I drilled the center of my wheels out, but my wheels are aluminum and very easy to drill. Either method will work. In this hobby, modifications are just part of the game. |
10-15-2011, 03:43 PM | #3 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
Hex's off a scx10, honcho, or dingo do not have the shoulder. And I have drilled wheels to fit shoulder hex's without any problems.
10-15-2011, 04:00 PM | #4 | ||
Thanks guys! | ||
10-15-2011, 05:14 PM | #5 |
RCC Addict Join Date: Apr 2008 Location: Georgia
You could grind down the step or nipple on the ( AX10 or Wraith ) hex right off with a dremel and use those wheels now. Or wait for the scx10, dingo, honcho hex's, which do not have the step/nipple thingy on them at all. |
10-15-2011, 05:35 PM | #6 |
Rock Crawler Join Date: Apr 2010 Location: America
very common easy fix buy a set with no raised section, should be 5-10 bucks
10-16-2011, 09:26 AM | #7 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
10-16-2011, 09:26 AM | #8 |
10-16-2011, 01:47 PM | #9 |
Rock Crawler Join Date: Nov 2006 Location: Spanish Springs, Nv
Post pics when you get them on. |
11-20-2011, 05:06 PM | #10 |
Newbie Join Date: Oct 2009 Location: Surrey, BC
So... did you get them on? I"m about to order these wheels too. A bit $$, but they look like they would look awesome!
11-20-2011, 09:16 PM | #11 |
Pebble Pounder Join Date: Sep 2009 Location: joppa,al
they are another set of hexes for the scx10 that have no raised portion, or do as i did and order another set of hexes and grind the raised portion off. running rc4wd dick cepek sidebiter 2.2's with no problem
11-20-2011, 10:17 PM | #12 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Man, I keep getting my hexes stuck in my rc4wd wheels....I've dremeled the shit out of them...never looked at the nipple getting stuck...that's coming off straight away
11-20-2011, 10:23 PM | #13 |
11-21-2011, 09:57 AM | #14 |
no... not sure of the name of them either...bought them from a guy at a garage sale...they've stuck to the Axial hexes no matter what rig I put them on...that nipple thing makes sense though...have to look at that.
11-21-2011, 10:07 AM | #15 |
here's a picture of them |
11-21-2011, 09:31 PM | #16 |
These are the ones I'm looking at |
11-21-2011, 09:44 PM | #17 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
I'm going with those as well later on
11-21-2011, 09:47 PM | #18 |
11-21-2011, 09:58 PM | #19 |
Will be. I'm ordering a wraith next week. Been out of crawling for a few years
11-22-2011, 08:20 AM | #20 |
Quarry Creeper Join Date: Nov 2005 Location: Italy
Guess it will end up way large with those wheels. Hope you like it that way...
