10-27-2011, 02:24 PM | #1 |
Rock Crawler Join Date: Oct 2008 Location: Italy
| tekin pro4 gearing
Hi, i'm Angelo from Italy, enough far from you in U.SA. but i read every day this forum and after some extreme crawling with my XR i decided to buy a wraith and i have to say that i 'm very satisfied with some little modifications.. my friend order for me this combo : MMP with tekin pro4 3300kv.. my question is : what's a good gearing for this set up to have wheel speed and to be able to run some scaler/crawler courses? 14/56 could be..? now i run goat 3s, 18.5 ballistic( 12.5 rotor), 20t pinion on 3s thanks to all |
10-27-2011, 02:42 PM | #2 |
14/56 would be a good start, or even smaller on the pinion. If you are using 48p gears then I would suggest 14/80 for 3s use. You will have a hard time overheating the motor, you will have more worries about trashing the drivetrain.
10-27-2011, 02:48 PM | #3 | |
i read also that tekin says that this motor needs a lot of amps and they suggest Rx8 but i think that ckecking temperatures there are no problems with MMP or not? MMP is rating for 100A continuous? | |
10-27-2011, 02:59 PM | #4 |
The MMP will be fine until you start going over 40mph. The motors are very amp hungry and low inductance, use a good battery. |
10-27-2011, 03:05 PM | #5 |
I run 14/56 32 pitch on my 3300kv Pro4 on 3s and am very happy with it.
10-27-2011, 03:13 PM | #6 | |
http://game-mania.it/index.php?main_...oducts_id=3144 A good choice..? Last edited by guidetti_angelo; 10-27-2011 at 03:18 PM. | |
10-27-2011, 04:44 PM | #7 |
Pebble Pounder Join Date: Dec 2009 Location: ca
Hi, I'm running 58/9 32p gears with my Castle 4 Pole 3800kv motor. It's so smooth it's hard to tell that it is not sensored. I use 3s and 4s lipo and it is tons of fun. 58t spur is from Jato and the pinion is a traxxas 9t 32p I show the starting and slow drivin smootheness towards the end of the video. http://www.youtube.com/watch?v=l-iuN8m1KVY |
10-27-2011, 05:06 PM | #8 | |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
I run a 3s 2600mah 30c pack and can tell it wants more. Also run a 4s 1750mah 45c pack and it seems ok. So I'd say any thing that can deliver minimum 75 amps continuous. Last edited by skid; 10-27-2011 at 05:12 PM. | |
10-27-2011, 07:46 PM | #9 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
12/58 gearing for me with an RS Pro and 3s 2200 45c battery. Best setup so far. 14/56 was just a little too fast and didn't have the bottom end control that I like.
10-29-2011, 07:07 AM | #10 |
Package has been sent to Italy! i also 13t pinion and 54t spur ( 32p) I can't wait eh eh I think it is a good set up to start.. |
10-30-2011, 01:46 PM | #11 |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
I have a MMP with a 3300Kv Pro 4. I'm running 14/56 on 2s and 3s. OMG this is too much fun.When running 2S I can hammer hard for a whole 5000Mah 40C pack and temps are running around 98* to 105*. Running 3s 5450Mah 50C adds around 20* to the temps.
10-30-2011, 05:22 PM | #12 |
| Very good ;) have you any video..? On 3s can you crawl or is it too fast..?
11-06-2011, 11:18 AM | #13 | |
thanks | |
11-06-2011, 11:34 AM | #14 |
| For what I do, 12 tooth pinion and trail runs, the motor only gets warm. I very rarely use full throttle, and for only about 3 seconds when I do. If your always doing speed runs or getting into a lot of binds, the temp may come up. Like you said, Tekin doesn't recommend 4s, so try at your own risk.
11-06-2011, 12:38 PM | #15 | |
yesterday i wired my tekin pro4 with MMP it is awesome!! 13/54 gearing start up is smooth and the motor is very fast when you need power! now i have to buy a good battery..45c constant.. | |
11-06-2011, 03:14 PM | #16 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
13/56 32p is perfect for me. Awesome lowspeed/decent top end.
11-06-2011, 03:18 PM | #17 |
11-06-2011, 03:23 PM | #18 |
| Personally - Dont think its needed. If you wanted more speed you could throw teeth at it and be fine IMO. 3,300 just provides that awesome lowspeed torque/no cogging..Everytime i take it out people are blown away its not brushed. |
11-06-2011, 03:33 PM | #19 |
11-06-2011, 04:32 PM | #20 |
I just got some in for stock. I was actually quite surprised at how weak the cog force was. I didn't get a chance to check the magnets or airgap, but they are certainly free spinning compared to a Neu/ Castle four pole. If the magnets check out the same strength and the airgap is the same then the tooth shape will be the culprit.
