11-06-2011, 02:31 PM | #1 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
| Stock Wraith Driveshaft bolt modification
Used a metric bolt.. Forget the exact size, I think 7mm maybe 8mm. Used the right length for lengt of driveshaft. I cut the head off the bolt and cut a slot in the end, Then threaded it in with a screw driver. It is an barely snug fit and will keep the shaft from collapsing and then twisting under more power than 2s with stock system. Sent from my highly abused iPhone using Tapatalk |
11-06-2011, 02:43 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Cool idea, is it holding up to some abuse?
11-06-2011, 02:50 PM | #3 |
Quarry Creeper Join Date: Mar 2010 Location: Los Angeles
I like the concept. Since the primary failure mode is collapsing when twisting it should add quite a bit of strength. The samething can be accomplished using a plastic rod or wood dowel without a loss of power from the added rotational mass.
11-06-2011, 02:53 PM | #4 |
Quarry Creeper Join Date: Nov 2005 Location: Italy
Any 6mm bolt or rod or tube will fit the same. Actually it's much easier (and lighter) to use 6mm alu tube (the one commonly found at DIY shops is 6mm OD and 1mm wall) Just cut to size, press it in and done, voilą! No more collapsed inner driveshaft. Mine is holding well, from August no more broken driveshafts, with 3s and long-case 650 motor, on any kind of use, also lot of rockcrawling |
11-06-2011, 02:54 PM | #5 |
The wood or plastic would work great too, but i wanted to to be removable to be able to change ends.. Sent from my highly abused iPhone using Tapatalk |
11-06-2011, 05:47 PM | #6 |
Rock Crawler Join Date: Nov 2008 Location: Beloit,ohio
I just used old axial alum links that I had laying around. Just used tubing cutter to get the right length. |
11-06-2011, 07:52 PM | #7 |
Rock Stacker Join Date: Jun 2008 Location: Walnut Ridge, AR
If you wanted to keep it really light, you could also use carbon fiber kite tube.
11-06-2011, 11:07 PM | #8 |
Quarry Creeper Join Date: Dec 2009 Location: in front of you...
i picked up a 4" brass door hinge pin and cut it in half...holds up to a mamba 5700 motor and clod tires...
11-07-2011, 02:32 PM | #9 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
Same idea linked here, different method Beefing up the stock drivelines I also sheared a few off at the begining of the splines after sleeving. |
11-11-2011, 08:10 PM | #10 | |
Sent from my highly abused iPhone using Tapatalk | |
11-11-2011, 09:33 PM | #11 |
Quarry Creeper Join Date: Aug 2008 Location: meriden
I did the same with a 1/4 20 bolt , works great
11-12-2011, 01:30 PM | #12 |
RCC Addict Join Date: Oct 2005 Location: rite here all along
i never understood how you guys are even blowing up the stockers anyway, ask any of the norcal guys that know me and I drive all my rigs like I stole them even my bruiser/blazing blazer hybrid, i was running my wraith with a brushless 3s set up and never broke anything but the front bumper and that was because I trimmed off the Dumbo ear hoops off of it |
05-24-2012, 12:00 PM | #13 |
Pebble Pounder Join Date: Oct 2006 Location: Montreal
| Re: Stock Wraith Driveshaft bolt modification
I did this mod with a 6mm aluminium tube, but there is now a lot of friction between the male/female sides... They don't slip together as smoothly as they did without it. The tube obviously expanded the diameter of the male shaft a bit.. Is this normal?
05-24-2012, 08:33 PM | #14 |
no...mine slides freely...
01-28-2015, 11:07 PM | #15 |
Newbie Join Date: Jan 2015 Location: Wash DC
I just took two 6Mx50 bolts, trimmed and slotted. Screwed them in and it slides just fine. I also turned my drive shafts around so the male spline is up near the trans. |
01-29-2015, 02:51 PM | #16 |
Pebble Pounder Join Date: Feb 2007 Location: Monrovia
| Re: Stock Wraith Driveshaft bolt modification |
01-29-2015, 03:02 PM | #17 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Stock Wraith Driveshaft bolt modification Not so much you would notice a "night and day" difference, but yes it does add to the rotating mass of the driveline. The ridiculously low gears in the crawlers sort of hides the added mass. So most people don't notice much if any loss in performance since the driveline still spools up quick due to the low gearing.
01-29-2015, 03:30 PM | #18 |
They won't notice any difference in that. It's not far enough from the center of the spinning to create much drag on the driveline at all let alone notice any difference at all. I agree in a technical sense it does add rotating mass but since the weight is so close to center it doesn't add much at all. |
01-29-2015, 04:34 PM | #19 | |
| Re: Stock Wraith Driveshaft bolt modification Quote:
Yes, if it were further out from center it would be more drastic and more people would notice, but that doesn't mean anything 3mm or less from center has no effect. Anyone wanting to try this with minimal added mass should consider 6mm dia. graphite rod or acetal (delrin), or aluminum bar, or anything lighter than steel. Last edited by Eric0424; 06-13-2015 at 11:40 AM. | |
