Thread: tranny swap, wraith, ax10, scx10 interchangable?
Old 11-10-2011, 07:51 PM   #1
Default tranny swap, wraith, ax10, scx10 interchangable?
The last weekspot I need to strenghen on my wraith, is the tranny. Im not looking to add a dig unit, was looking at the crkc all metal tranny for the ax10/scx10. Are they interchangable with the wraith? I know the direction is backwards on the drive, cause the tranny is turned 180 degrees compared to the scx10/ax10. Anyone done this? I havent found an all metal tranny advertised for the wraith yet. any ideas???
summervillecrawler is offline   Reply With Quote
Old 11-10-2011, 08:05 PM   #2
Get the vanquish scx ax10 case if you want to buy a new case. You could also buy a scx/ax10 plastic transmission case. All you need is a 2 pack of
bearings (axa1225). Then get the 2 robinson racing gears. They replace the out drive. And the axa80010(idler gear?). Ive done the swap.
im gunna crawl is offline   Reply With Quote
Old 11-10-2011, 08:47 PM   #3
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
The Wraith case is different then the other kits. The VP case works if you plan on running a dig. Otherwise you end up needing a really long driveshaft.
The case is not an immediate weak point, just the internals.
Harley is offline   Reply With Quote
