11-14-2011, 05:09 PM | #1 |
Rock Stacker Join Date: Nov 2011 Location: united states
| wraith question
So i got my wraith and its awesome I just noticed one thing when I go full forward or reverse it hesitates I have a cheap battery in it now I plan on a better one soon. Anyone have an idea let me know what's up thanks
11-14-2011, 07:41 PM | #2 |
Rock Stacker Join Date: Nov 2007 Location: Billings
This question has been asked before, and could be found with a search or simply looking back a page or two. But I assume that the cheap battery is a nimh, and if so the voltage drop that occurs when you go full boar on the skinny pedal either forward or backwards kicks the lipo cutoff feature on. It's set to on from the factory. If you are going to continue to run nimh than you need to use a castle link( since the esc is basically castle) and turn the lipo cutoff off. Or you could buy a lipo and run it until one of the other highly documented failures occur.
11-14-2011, 08:29 PM | #3 |
Quarry Creeper Join Date: Mar 2008 Location: Pittsburgh
I'm pretty sure you can manually change the setting on the stock esc if you don't have a Castle Link.
11-15-2011, 11:48 AM | #4 |
Newbie Join Date: May 2011 Location: Uk coventry
sorry im trying not to hijack the thread ive got the same problem and im running 2s lipo what this about lipo cut off dont you need that on so you dont drain the battery to much
