11-14-2011, 05:31 PM | #1 |
Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
| Using Revo Pushrods as Suspension Links
I was asked about these in a post I made, so here is how I made it work. The push rods that you need are # TRA5318 and you will need 4 packages. You will also need 1 package of Jato rod ends # TRA5525. You will first need to replace 1 short rod end of each push rod with a longer Jato rod end. In order to bend the upper link, I used my brake line bender. You can see in the photo that I butted the short rod end up with the edge of the rotating part of the bender. I bent the push rod until the long rod end hit the upper part of the bender that holds the brake line down. If you have a different style bender, the bend is ~30 degrees after it springs back. Here is one of each of the finished links. Here they are on the truck. |
11-14-2011, 05:59 PM | #2 |
11-14-2011, 07:09 PM | #3 |
Quarry Creeper Join Date: Mar 2008 Location: Pittsburgh
Are they the same length as the stock links?
11-14-2011, 07:17 PM | #4 |
Quarry Creeper Join Date: Feb 2008 Location: Albany
Nice Idea!!! I have been meanin to get a bender like that!
11-14-2011, 08:01 PM | #5 |
| If you use the rod ends that I listed they are very close in length. I have my uppers threaded all the way in, and my lowers are just a turn or two out. Also, the bending is done with the rod ends threaded all the way in. |
11-14-2011, 08:14 PM | #6 |
Rock Crawler Join Date: Nov 2011 Location: Wister, OK.
Thanks, looks like I need to place an order for some more stuff!
11-14-2011, 09:41 PM | #7 |
Rock Crawler Join Date: Nov 2009 Location: poteau
are your lower links just straight? did you use bent rod ends on them? i would think that IF they were straight with straight ends you would get some binding of the links during articulation.
11-14-2011, 10:24 PM | #8 |
11-14-2011, 10:38 PM | #9 |
Rock Stacker Join Date: Apr 2009 Location: sheilock
hmmm thats pretty sweet! now that gives me an idea! |
11-15-2011, 05:27 AM | #10 |
| I am running the links straight and I don't notice any binding in the links. The rod ends slightly rub on the skidplate but not enough to cause issue. I rotated the ends to get rid of the rubbing through most of the travel. To totaly eliminate the rubbing, you can just file a little bit on the skidplate.
11-18-2011, 11:05 AM | #11 |
Quarry Creeper Join Date: Nov 2011 Location: Vacaville
There appears to be a couple different lengths of Revo pushrods, do you happen to know which length you used? Thanks, ~Chip |
11-18-2011, 12:30 PM | #12 |
11-19-2011, 08:15 PM | #13 |
I used the Traxxas 5319 Black Steel for my lower. They are a drop in fit! For the uppers I used your Idea! Awsome! Thanks for a cheap & easy up-grade! My wheel base is 14" Last edited by skywker51; 11-20-2011 at 08:46 PM. |
11-19-2011, 11:19 PM | #14 |
Took your advice TMXNOR and built my own links, pretty easy and worked great! |
11-20-2011, 09:43 AM | #15 | |
I'll have to check those 5319's out. | |
01-18-2012, 05:18 PM | #16 |
| Re: Using Revo Pushrods as Suspension Links
Great ideas! Thanks!
01-18-2012, 05:22 PM | #17 |
Just so you know the chrome ones are brittle where the the threads end. I have had much better luck with the black steel ones, but they rust.
01-18-2012, 06:30 PM | #18 |
| Re: Using Revo Pushrods as Suspension Links |
01-18-2012, 06:38 PM | #19 |
Great find. They also make the same links in aluminum. But if you do bend them, they can snap pretty easily. I have used the aluminum ones, in varying lengths on numerous rigs. |
02-12-2013, 09:33 PM | #20 |
Newbie Join Date: Feb 2013 Location: North Little Rock
Hey guys I know this is an OLD thread but Im new and looking to do this up grade! My question is can I use both rod types or just one or the other? #tra5319(139mm) lowers and uppers? Or a combination, #tra5319 as lowers and the #tra5318(102mm) as uppers? They are different length and wanted to make sure once I bend them they will fit correctly? Thanks for knowledge! |
