11-28-2011, 07:27 PM | #1 |
Quarry Creeper Join Date: Aug 2011 Location: Australia
| 4WS help
Hi guys, I am getting a wraith for christmas and the first upgrade will hopefully be 4WS. setting it up would be pretty simple, i just dont know what exactly i need, can you guys help me list all the stuff? Thanks, Joel |
11-29-2011, 11:33 AM | #2 | |
Quarry Creeper Join Date: Aug 2008 Location: meriden
11-29-2011, 05:48 PM | #3 | |
Newbie Join Date: Oct 2011 Location: Easthampton
I just ordered the parts for it myself! What you can do to save cash is buy aluminum parts for the front end and just put the plastic parts in the rear end. So purchase aluminum c-hubs, knuckles, stronger servo, universals, metal steering arms and so on. Then just put the stock plastic parts and the old servo in the back. The first upgrade no matter what is the universals! The stock c-cups and dog bones will often destroy the stock plastic parts. | |
11-29-2011, 06:59 PM | #4 | |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
11-29-2011, 07:41 PM | #5 |
Newbie Join Date: Nov 2011 Location: Cincy, OH
Plus I would be worried about the stock steering servo being reliable. I just stripped mine out after my 3rd run. A good quality one is a definite for me.
11-29-2011, 08:51 PM | #6 |
heyy guys, thanks for the help. its been so helpful. thanks EGG to start off, i am most probally going with the some of VP parts, for durability. i am going tobuy all this stuff this weekend. Eion and wartrader, thanks for the tips. good work guys.
11-29-2011, 09:58 PM | #7 | |
11-30-2011, 12:19 AM | #8 |
Sometimes, I make things. Join Date: May 2009 Location: Mt. Upton
You will want a strong rear servo otherwise it will tirn easily on climbs and in binds when you dont want it to. I would say on a 4ws rig the rear servo being strong is more important than the front, so if you go that route, you will want to get a CC BEC too. I broke a stock front knuckle then ended up building a pretty decent 4ws truck, $600 later its a pretty solid rig, haha. I tend to do that, when i break something small, i just replace everything.On my Honcho, i broke the rear 3link mount and then it turned into an 1/8 scale motored, 2 speed, 6.25" tired monstrosity. |
11-30-2011, 12:28 AM | #9 |
damn, crazyorigin, that honcho sounds, EPIC!!!! i definetly will need another CC BEC or just one CC BEC pro.
11-30-2011, 11:29 AM | #10 |
I am running my 2 8711 servos off one CC BEC and it is working fine, i dont think 2 are necessary, it will send the same voltage to both servos. I have seen people running 2 BEC's but they usually use the 2nd one to control power to lights or a winch, one for steering duties should be adequate. If you buy one from Holmes Hobbies, he will program it to whatever voltage you want, if you dont have a Castle Link it is a nice option to have. I have torn back into the "honcho", it isnt really a honch anymore tho, pretty much all thats left from it is the framerails and a couple crossbraces, i should have some updates soon. It basically tries to destroy itself evreytime you hit the throttle, especially with how i drive. I thought my axles were beefy but i am working on reuilding them and they are pretty torn up, twisted rear axleshafts, and a curly Felsenfest CVD up front, but its not thier fault, it is really pushing the boundaries with the tires, and 2200kv 1/8 scale setup, plus i drive like a fool. I should have updates on that project and my Wraith soon, the "honcho" is basically a Mud dragster/Megatruck themed rig ("Hill'n'Hole Heavy Hitter" in FOFF section) , i am going for more of a crawler style with the Wraith. |
11-30-2011, 06:31 PM | #11 |
nice man, thats what i want my wraith for, like a crawler/basher. I just checked bout holmes hobbies setting a voltage, that sic. i think ill definetely go with them. i have no idea what voltage ill need though, what do you think ill need? ill run the two servos off it?
11-30-2011, 10:11 PM | #12 |
That really depends on the servos you choose to run. If you choose a high end powerfull set of servos, like something 300oz or more you should be able to run them off 7.4volts, i am running my 8711's on 7.4, that is pretty much the max voltage most any 1/10 scale servo will handle. Whichever servos you choose, you should be able to find the recommended voltage for that servo in the manufacturers specs. Running them at a lower voltage will be easier on them, less heat and abuse, but you will suffer power shortage. I had forgotten to set the voltage on my servos initially and they were not very strong, not much stronger than the 2075's were running off the ESC's power but after setting them to 7.4 they are beastly.
12-03-2011, 09:37 PM | #13 |
thanks for all the advice guys, big help
Tags |
4ws, wraith |
