12-05-2011, 12:06 PM | #1 |
RCC Addict Join Date: Nov 2011 Location: cold state
| Wraith transmission using 32 pitch spur gear
I need some help with a upgrade that some of you have done to running wraiths. I'm looking for direction on using wraith transmission but use 32p spur gear. What I'm using is Novak 13.5 wraith edition timbuk2 system with rc4wd driveshafts punishers. Using a 3800mah 60c battery as well. I know of the bombproof setups but not to familiar with the 8mm shafts. Basically looking for the best of the best transmission. Already have HR harden steel gears in tranny. POST PICKS WILL HELP TOO!
12-05-2011, 12:18 PM | #2 |
So, you need to know which spur and pinion gear to use?
12-05-2011, 02:05 PM | #3 |
12-05-2011, 02:53 PM | #4 |
Rock Crawler Join Date: Nov 2011 Location: Wister, OK.
I'm running a 14 and 60 and love it, Tekin 45t on 3s LiPo's.
12-05-2011, 03:02 PM | #5 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
14/54 here. I havn't run it much but I did crawl on my rock pile with it and it was plenty smooth power delivery with the 13.5. Top end was a little faster than stock.
12-05-2011, 03:49 PM | #6 |
| Great video update by the way! More to come? Was there a reason why you went with nylon spur gear rather then metal
12-05-2011, 03:53 PM | #7 | |
Quarry Creeper Join Date: Dec 2011 Location: Fayetteville, AR
Fink | |
12-05-2011, 08:09 PM | #8 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
I've also read on here that the metal spur is very noisy. Makes sense.
12-06-2011, 05:38 AM | #9 |
Quarry Creeper Join Date: Oct 2005 Location: Bryant, AR
I run a 54t Kimbrough spur and a 13t RRP pinion. Here is a link to my build. TMXONR's Cherokee Wraith Last edited by TMXONR; 12-06-2011 at 05:41 AM. |
12-06-2011, 06:56 AM | #10 |
12-06-2011, 07:26 AM | #11 |
It all makes sense, thanks for all the input.
12-06-2011, 08:16 AM | #12 |
Rock Crawler Join Date: Jul 2009 Location: greeley
12-10-2011, 09:43 PM | #13 |
Newbie Join Date: Dec 2011 Location: Australia
Quick q guys About to order my Wraith on Tues Following items already ordered 80 amp Sensored esc $40 Xcelorin 21.5 T can $55 Program card n extras $15 4000 mah 3S 40c lipo $27 What I need now are the pinion and spur in 32P I believe Traxxas spur will work? Then I just need any 32P pinion @ 3.17 mm shaft size yes? Now I cant find KV specs on 21.5 can, what would be a good spur/pinion combo to keep same stock speed as RTR? I wont be doing mental crawling, but I will be doing pretty much trail with hill climbs Any assistance greatly appreciated |
12-10-2011, 10:09 PM | #14 |
I used a Durateax spur and Robinson pinion.
12-11-2011, 12:40 AM | #15 |
RCC Addict Join Date: Sep 2009 Location: sacramento
im running a traxxas 56 spur and rr 14 pinon = 4.00 gearing with 13 t hh crawlmaster on 3s and it works great good speed and great for crawling its my g6 rig
12-11-2011, 12:51 AM | #16 |
Dan, quick q, I just ordered 4 of the same What does hold it on the shaft? Stock bush supplied with Wraith Kit? If so I should be all good ;) |
12-11-2011, 01:48 AM | #17 |
That half of the slipper has a raised center that fits snuggly into the spur for centering. If that's what you're asking.
12-11-2011, 01:52 AM | #18 |
Yeps, thats what I needed to know, cheers I have all my stuff ready to come in, just need to order Wraith with steering set up and will be right ;) |
12-11-2011, 10:07 AM | #19 |
How are y'all running the Traxxas spurs? The center of the Traxxas gear is too large to properly sit on the Axial slipper plate. Also the bolt circle of the Traxxas gear is just slightly smaller than the bolt circle on the slipper plate of the wraith. Are you guys drilling out the Traxxas gear to match the bolt circle or are you not even paying attention and letting the slipper plate get crossthreaded? What are you using to keep the spur gear centered on the plate? The Kimbrough gear that I am using fits the raised portion of the slipper plate and the bolt circle is the same, so it fits perfectly. I haven't tried the Duratrax spur, so I can't comment on it. |
12-11-2011, 11:02 AM | #20 |
