12-05-2011, 12:43 PM | #1 |
Quarry Creeper Join Date: Nov 2011 Location: San Diego
| What aftermarket spur gears fit?
Which aftermarket spur gears fit the wraith that I can find in my LHS. They don't stock much Axial stuff and I need to get some spurs. What other brands will work?
12-05-2011, 12:48 PM | #2 |
Newbie Join Date: Oct 2011 Location: Canada
In my research to find a 96t spur for my Wraith, I concluded that Kimbrough spurs fit. I can let you know if it fits right in a few days... Tom... Last edited by Tom17; 12-05-2011 at 12:52 PM. |
12-05-2011, 12:55 PM | #3 |
Thanks, I am looking for an 87 and 84...
12-05-2011, 06:10 PM | #4 |
Rock Stacker Join Date: Oct 2011 Location: vancouver
87t 48p fits but i think if you go any bigger you have to modify the housing or dont use it
12-05-2011, 06:44 PM | #5 |
Newbie Join Date: Aug 2009 Location: SAGNASTY
87 will definitely fit and I agree with Tom...go with Kimbrough gears!
12-05-2011, 07:34 PM | #6 |
12-06-2011, 01:03 AM | #7 |
Quarry Creeper Join Date: Jul 2011 Location: Seattle
| The white Traxxas gears work with a small mod. The three mounting holes need to just be slightly enlarged with a drill bit, and they are hub-centric to the Axial mount, so they center perfect.
12-06-2011, 01:15 AM | #8 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
87 is the biggest that will fit as far as I know. There is not that much clearance between the driveshaft and spur
12-06-2011, 04:14 AM | #9 |
Newbie Join Date: Nov 2011 Location: canada
32 p duratrax evader st nitro
12-06-2011, 05:30 AM | #10 |
12-06-2011, 07:53 AM | #11 |
seen one with a 90t had a slight mod to the case for it to fit. why they show it in the book who knows prolly just for a broader range more examples of gear ratio. my 87t is snug but fits fine.
12-10-2011, 10:49 AM | #12 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
i wanna lose teeth and go a bit smaller say 78-................. anyone know who or where ?
12-10-2011, 12:40 PM | #13 |
12-11-2011, 12:24 AM | #14 |
Hmmm, my 12t titan, now on 23/80 doesn't get warm, has good take off and not bad speed. I reckon it could quite happily pull higher gearing. Even after a thrash its still got no real temperature to it.
12-13-2011, 08:05 PM | #15 |
Right. It's official, the 96t 48p spur does NOT fit. I can post a pic if you like but yeah, it hits the driveshaft as expected. It's realllly close though. If the driveshaft was about 5mm further out from the gearbox, it would be fine. I put my standard 80t back on. Interestingly, there is not enough adjustment to use my 12t pinion with that 80t spur, it does not make contact. So my first lesson of RCC, don't believe everything you read in the instructions Is 87t the biggest I can go? I don't care about getting the dust cover back on so I was wondering if the 93 would work. Yeah i'm a glutton for punishment So my journey of learning through trial & error begins! Tom... |
