12-12-2011, 12:20 PM | #1 |
Rock Stacker Join Date: Apr 2011 Location: seattle
| Lowering the Wraith
I was poking through Harley's mega-thread and really like the look of the lowered Wraith he came up with using the Proline PowerShocks. Are all four shocks the Slash front shocks ? Also, recommended spring set up? This is mostly a basher build, I have other cars dedicated for speed and crawling, so looking for overall decent performance in most conditions, not optimizing for any specific terrain or activity. |
12-12-2011, 12:25 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
I use proline powerstroke slash's aswell. Front for the Front, Rear for the Rear.. I went ahead and shelled out the extra cash for both spring kits aswell.. Im currently running blue primary and secondarys all the way around (softest in the spring kits) with 20wt Losi oil on all 4 corners and i love the way my rig handles and it is pretty general purpose. Crawl, Trials,Trails,High speed.. Seems like a good Overall combo.. If you run at a higher rate of speed consistently you could easily throw a stiffer primary (short spring) and keep a softer secondary. EDIT: I decided on rear's for the rear for a little bit more reach while crawling and those big hits @ high speed.. Seems to be working for me. Last edited by DiEzel; 12-12-2011 at 12:28 PM. |
12-12-2011, 12:33 PM | #3 | |
Right on - thanks! Exactly the info I was looking for. Will probably order up the full set then, and play around with springs to see what's appealing Quote:
12-12-2011, 12:59 PM | #4 | |
