12-13-2011, 10:47 AM | #1 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
| New Axial Wraith Option Parts HD Servo Horns AX30834 Aluminum Servo Horn 23T (Hard Anodized) AX30835 Aluminum Servo Horn 24T (Hard Anodized) AX30836 Aluminum Servo Horn 25T (Hard Anodized) If you drive your Axial based rig hard, then you already know how tough the rocks can be on a servo horn. Upgrading to Axial's new HD aluminum servo horns will give you added piece of mind on those all day expeditions. CNC machined from 6061 billet aluminum for precision and strength. Hard anodized for durability. Available in 23, 24 and 25 spline counts to fit most servos. Clamping style head for secure mounting in high stress applications. 16 and 20mm threaded mounting holes for adjustability. Laser etched Axial logo. HD Aluminum Straight Links AX30790 Axial Machined Heavy Duty Aluminum Straight Link 101mm - Grey (2pcs) CNC machined from billet aluminum for precision and strength. Classic grey anodize. Direct replacement for the links on the Wraith Kit AX90020, or for the Wraith RTR AX90018 you'll also need AXA1331, AX80057 and AXA187. Laser etched Axial logo. Sold in packs of two. AR60 OCP Machined Low-Profile Differential Cover AX30829 Axial AR60 OCP Machined Low-Profile Differential Cover CNC machined from billet aluminum for precision and strength. Hard anodized for durability. Direct replacement for stock plastic diff cover. One differential cover per package. Laser etched Axial logo. AR60 OCP Machined Link Mounts AX30830 Axial AR60 OCP Machined Link Mounts CNC machined from billet aluminum for precision and strength. Hard anodized for durability. Laser etched Axial logos. Multiple mounting holes to fine tune wheelbase. Threaded mounting points for the axle, lower links and shocks. Two mounts per package. Easy to install. AR60 OCP Aluminum Straight Axle Hub Carriers AX30789 Axial AR60 OCP Aluminum Straight Axle Hub Carriers (2pcs) CNC machined from billet aluminum for precision and strength. Black anodize. Direct replacement for the stock plastic carriers. Two aluminum lockouts and four M3x6mm set screws per package. Laser etched Axial logo. Sold in packs of two. Hi-Clearance Threaded Aluminum Links AX30791 Axial Hi-Clearance Threaded Aluminum Link 7x85mm - Grey (2pcs) CNC Machined from 7mm diameter aluminum for strength. Bent for driveshaft clearance. Classic grey anodize. Direct replacement for Wraith kit and RTR upper links. Drilled and tapped for M3 hardware. Laser etched Axial logo. Sold in packs of two. Stage 1 Aluminum Links Kit AX30797 Axial Wraith Stage 1 Aluminum Links Kit Add even more durability to your Wraith by upgrading your stock plastic RTR suspension links with our HD Stage 1 Aluminum Link Kit. Replaces all the stock plastic suspension links with high quality 7mm diameter aluminum links. Eliminates axle wrap and unwanted axle steer, especially in high power applications. Kit includes 4 aluminum bent upper links and 4 aluminum straight lower links. CNC Machined from 7mm diameter aluminum for strength. All hardware and rod ends are included. Classic grey anodized links. Direct replacement for Wraith kit and RTR upper and lower links. Adds strength for high power applications. Laser etched Axial logo. Visit our Press Page for more info: Axial Racing - Press : Download : Images / Press Releases |
12-13-2011, 10:50 AM | #2 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
sweet |
12-13-2011, 11:13 AM | #3 |
RCC Addict Join Date: Nov 2011 Location: cold state
When are these available to order?
12-13-2011, 11:14 AM | #4 |
12-13-2011, 11:18 AM | #5 |
Are the diff cover and horn only in that copper color?
12-13-2011, 11:24 AM | #6 |
12-13-2011, 03:05 PM | #7 |
Rock Stacker Join Date: Dec 2011 Location: calverton
Where can these be ordered from? specifically the HD link set?
12-13-2011, 03:47 PM | #8 |
12-13-2011, 04:20 PM | #9 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Lovin the diff covers |
12-13-2011, 04:27 PM | #10 |
Quarry Creeper Join Date: Dec 2011 Location: Huntington Beach
12-13-2011, 04:30 PM | #11 |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
These items can be ordered at any local hobby shop or through any of the online vendors on RCCrawler.com. Because they were just released it may take a day or two for the shops to get the info into their systems. |
12-13-2011, 06:09 PM | #12 |
Rock Crawler Join Date: Aug 2011 Location: tri cities
The 101mm links are longer then the stock correct?
12-13-2011, 06:15 PM | #13 |
12-13-2011, 06:24 PM | #14 |
Newbie Join Date: Sep 2011 Location: Rockland, ontario
While we're on the subject...I've seen Axial sway bars in an add I found in the RC Car action buyers guide...but I can't seem to find the product anywhere....
12-13-2011, 07:08 PM | #15 |
It says the link mounts are threaded for the bolts that retain them to the housing. I can't tell by the pic, but can you also still use a nylock nut on those bolts? And, uh, when's the dig available? |
12-13-2011, 07:39 PM | #16 | |
No, you can't use a nylon lock nut on these, there is not a flat spot for the nut to fit on, additionally there is added material that would cause the nut to interfere with the links/shocks. Just use a little bit of blue threadlock if you are worried about the screws working loose. | |
12-13-2011, 09:22 PM | #17 |
Quarry Creeper Join Date: Feb 2008 Location: Albany
12-13-2011, 11:14 PM | #18 |
Pebble Pounder Join Date: Feb 2008 Location: 808
Cool rite on Bender!! Thnx for posting up these new upgrades. I like those upper links!
12-13-2011, 11:25 PM | #19 |
Rock Crawler Join Date: Jul 2010 Location: SLC
I'll be able to supply these as soon as they are available at my distributor |
12-14-2011, 07:59 AM | #20 |
Rock Crawler Join Date: Nov 2011 Location: Wister, OK.
I need some of these AR60 OCP Machined Link Mounts! Cool stuff. |
