How to set up rear steering with Wraith i am looking for some pictures or anything. i am not sure, will my battery get low. or will it go dead? if i set up the rear steering on my wraith? i am just wondering...... thanks. |
Re: How to set up rear steering with Wraith Your battery has nothing to do with the rear steering. If it gets low or goes dead then you need to recharge it regardless of how many axles steer. 1 more HT servo is not going to draw all that much more power that you will have battery issues but will reduce your drive time some. How to do it? Well you will need a 4 channel radio unless you want to Y-harness the 2 servos together but then you will loose your trim ability of each individual servo. Will need a steering axle to put under the rear. Dont know if its been cobbled together yet on the Wraith. |
Re: How to set up rear steering with Wraith you need to start with this ... http://i494.photobucket.com/albums/r...1/DSCN0856.jpg http://i494.photobucket.com/albums/r...1/DSCN0858.jpg My build isn't even close to being done but I have some more info on my build thread here http://www.rccrawler.com/forum/axial...aith-v2-2.html |
Re: How to set up rear steering with Wraith |
Re: How to set up rear steering with Wraith okay, i am looking at another wraith with rear steering. well, i am wondering, is it enough for my AR-3 2.4GHz RECEIVER with rear steering? will it work? |
Re: How to set up rear steering with Wraith Quote:
Hahaha :lmao: Harley you are so matter of fact! I cant number the posts you've replied to questions with a LINK and boop, Done!! I agreee with harley on the 4pl so you can set your trim up on the rear. Otherwise with the y-harness the rear turns at the same time the front does so good luck not flipping while turning if your bashing at higher speeds. You also wont be able to do the "crab walk" which is very usefull in some technical situations. |
Re: How to set up rear steering with Wraith alright, i don't mind. i will just try to set up rear steering on my wraith. |
Re: How to set up rear steering with Wraith Can you use the traxxas 4 channel radio and 5 channel reciever that comes in a summit to run a rear steer setup? How well would it work? They are a lot cheaper than th 4pk. |
Re: How to set up rear steering with Wraith I was able to get rear steer to work quit nicely with a Spektrum DX3C transmitter, has rear steer mix etc. I do however need to depress the scroll wheel twice to activate the "crab walk" but set the rear steer with the thumb switch for the on/off. Works nice for and the TX w/1 RX was under $140.00 |
Re: How to set up rear steering with Wraith I use my DX3r for my rear steer. Just have it toggle independantly from the front, like on the 1:1. Only thing is it is set to turn to full lock whereever you have that set but that is generally not an issue. |
Re: How to set up rear steering with Wraith Ok I know this question will probably get flamed or moved but I have to ask anyway since it directly involves the rear steering. the question is: Is there a way to get a seperately controlled rear steer that doesn't work off the radio wheel control. Kinda like a joystick in a 1:1 rig idea. Or is it even possible to do? I guess just to give an example is if my wraith is going up a hill and the front wheels were turned to the right and I needed to move the rear wheel back and forth with out moving the front. Is there a way to do that or is it impossible due to electronics? Almost like if you had 2 people driving the same rig one controlling the front wheels and and one controlling the rear wheels. |
Re: How to set up rear steering with Wraith What does this mod cost total? Minus the receiver |
Re: How to set up rear steering with Wraith Alright thanks Harley. I would want a pretty strong rear servo right? So when I'm just using front steer the rear tires don't get pushed sideways by rocks? And I'm on a budget so I'll start with a stock axle and upgrade when things break. What is a cheap receiver you would recommend? |
