01-08-2012, 07:06 PM | #1 |
Quarry Creeper Join Date: Nov 2011 Location: San Diego
| Esc setting question.
I am running a Mamba max pro with a tekin redline 10.5 My esc settings have the motor direction at normal. My reverse is set at 50% so I am not sure if it is faster in reverse than forward. I am used to running 1/8 scale with 2200kv motors at 40-50mph so it all seems slow to me. My question is with this setup should I run the motor direction in reverse?
01-09-2012, 08:09 AM | #2 |
| Re: Esc setting question.
Anybody else running a mmp and redline motor?
01-09-2012, 08:40 AM | #3 |
Quarry Creeper Join Date: Mar 2010 Location: Los Angeles
I'm running a Redline and MMP. Mine was swapped into a RTR that was running with the motor reversed from the factory (because of the way the diff's were assembled). Since I left the diff's as is, I used the castle link to specifiy a reverse rotation motor when I programmed the MMP. Then I needed to set the throttle swith on the transmitter to "N" for normal. I also have reverse set to 50% and my reverse is definitly what it should be. Are you use to running 1/8 scale 2WD buggies? If so it's probably the final gear reduction that you are not use. Between the tranny and the diff's I believe there's quite a bit more reduction then typical in a 2WD buggy. |
01-09-2012, 09:51 AM | #4 |
Rock Crawler Join Date: Dec 2007 Location: Shreveport, La
im running that combo except its a 13.5, just got it running this weekend and i have hardly any reverse. waiting on a castle link to do some tuning it was a kit wraith and i put the diffs together the way the book says and hook up the motor normal, tx is set to normal direction also |
01-09-2012, 11:23 AM | #5 |
Rock Crawler Join Date: Nov 2009 Location: poteau
i was running an 18.5t brushless. i swapped the ring and pinions around so the motor turned the normal way. what i found out was with the stock setup the motor turned the opposite way. you either had to reverse the esc or reverse the controller. when i had the controller reversed i could not use the boost options. when i swapped the esc to reverse i could use the boost, but my motor came with 30* advanced timing and it just didn't seem right. motor would get hot in about 20 minutes. i eventually swapped the ring gears around and set the esc and controller to normal. everything was great then.
01-09-2012, 12:53 PM | #6 |
Thanks, I will switch my esc settings to reverse the motor.
01-09-2012, 02:38 PM | #7 |
better off just pulling the ring gear and flipping the ring gear/locker around. takes 10 minutes to do both ends.
01-09-2012, 02:46 PM | #8 | |
Rock Crawler Join Date: Sep 2011 Location: FNQ Australia
| Re: Esc setting question. Quote:
Esc setting question. - Similar Threads | ||||
Setting up a HPI Jolt R esc? | TurboShadow | Electronics | 1 | 06-20-2011 11:17 PM |
sidewinder esc setting | yfz350 | Axial AX-10 Scorpion | 5 | 02-19-2010 04:24 PM |
Which ESC Brake/Reverse Type Setting on my Mamba Max ESC? | b00st3d | Venom Creeper | 3 | 01-24-2010 04:34 PM |
Questions on setting up ESC and Transmitter | needtocrawl | Electronics | 10 | 11-28-2009 10:25 PM |
setting up esc | CrawlerDan | Electronics | 2 | 01-13-2008 02:07 PM |
