Thread: Axle Setscrews
Old 01-28-2012, 11:30 PM   #1
Default Axle Setscrews
Has anyone else had issues removing the setscrews for the axles?
I got a set of heavy duty axles from CKRC but I cant seem to set the darn setscrews out. I stripped two of them, but I wanted to see if anyone had any suggestions before stripping the other 2, lol.
Many thanks for any suggestions!
lccguy is offline   Reply With Quote
Old 01-29-2012, 12:19 AM   #2
Default Re: Axle Setscrews
I am assuming you are actually talking about the driveshaft pins? The trick here is to use a quality allen driver. Most typical allen keys are too soft and will simply strip the allen pin.
NFA Fabrication is offline   Reply With Quote
Old 01-29-2012, 09:26 AM   #3
Use a soldering iron on the screw to loosen up the locktite. It should come right out. If not, you might have to drill them out. I had to do that to one of mine.
slickwillie is offline   Reply With Quote
Axle Setscrews - Similar Threads
rear straight axle lock out's for tamiya tundra highlift axle tundrafan01 General Scale Talk 9 05-19-2011 01:30 AM
Junfac DS setscrews TrailDawg362 General Crawlers 10 11-19-2010 03:43 PM
stripping outputs (driveshaft setscrews) booger weldz Axial AX-10 Scorpion 3 12-06-2008 03:55 PM
