01-31-2012, 05:41 AM | #1 |
Rock Stacker Join Date: Nov 2011 Location: Summerville SC
| axle question, Large scale heavy duty axle?
My wriath, as some may have seen, is boarder line large scale, with the huge venom powertrain and 40 series mudslingers, so here is my question... Is there an axle anyone would recomend that is about 1.5 inches or so wider, and is super beefy with larger axle shafts 17mm hexes, and is set up similar to the wraiths? The current axles housing are holding up ok, I keep snapping axles, destroying bearings, etc. I snap hardened shafts, have the rcwd alum housings, etc etc...The power and rotating mass of those huge tires are to much for it. Fixing to have to buy new knuckles and c hubs(again), just replaced axles and bearings...AGAIN!!! Please, any help would be greatly appreciated! Pug |
01-31-2012, 06:56 AM | #2 |
Twin Force axles.
01-31-2012, 07:56 AM | #3 |
| Re: axle question, Large scale heavy duty axle?
Thanks harley, I will look into them to see if I can find a kit, to experiment with. Pug |
01-31-2012, 10:05 AM | #4 |
Any other ideas? The only place i found themis rcp, and they want 175 for one axle "kit". way too much for "experimenting"...
01-31-2012, 10:12 AM | #5 | |
Try TXT axles. But they aren't the same orientation as they are a top loading axle like a Rockwell. | |
01-31-2012, 10:57 AM | #6 |
| Re: axle question, Large scale heavy duty axle? Yes, these. Stay far far away from TXT axles, they are weak design and the housings are made from cheap plastic that likes to crack and break easily. Any large scale truck like OP described that breaks Wraith axles will destroy TXT axles. Last edited by Natedog; 01-31-2012 at 11:00 AM. |
01-31-2012, 01:38 PM | #7 |
| Re: axle question, Large scale heavy duty axle? |
axle question, Large scale heavy duty axle? - Similar Threads | ||||
heavy duty bevel gear question | klcrawler | Axial SCX-10 | 6 | 10-26-2011 10:01 PM |
Bully 2.2 Axle Heavy Duty XVD v6 | krazycrawler888 | RC4WD Bully | 5 | 07-12-2011 09:48 PM |
Bully 2.2 Axle Heavy Duty XVD v6 | Boids | RC4WD Bully | 21 | 07-02-2010 09:51 AM |
