02-04-2012, 09:45 AM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: Silverton
| do you really need a receiver antenna
02-04-2012, 09:58 AM | #2 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
For the distances we use while crawling or trail running ... Leaving the antenna rolled up internally is fine. There is a slight reduction in range but nothing we'll notice. I you start racing and get 100'+ away from you car you'll probably want to stand the antenna up again. Heck, I used roll my 27mhz AM antenna's internally without any issues crawling. Sent from my HTC Desire HD A9191 using Tapatalk |
02-04-2012, 10:02 AM | #3 |
Rock Crawler Join Date: Nov 2011 Location: Wister, OK.
| Re: do you really need a receiver antenna
I always just tuck mine in the rx case or Scotch tape it to the top of the rx. |
02-04-2012, 10:07 AM | #4 |
Thanks for the info. I guess i am still living back in the AM radio days. |
02-04-2012, 11:08 AM | #5 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
some rx antenna's are short as to why you dont see them.. i route mine as to not coil it up.. cuase there aint no telling what im gonna be doing with it. |
02-04-2012, 11:20 AM | #6 |
I usually have a 4-6" antenna tube coming out of the rx box just in case. As was said, don't know what I'll feel like doing and would rather not worry about range. But there are a couple guys that coil up the wire into the case of the rx itself and don't seem to have much issue within crawling tx ranges.
02-05-2012, 12:23 AM | #7 |
Newbie Join Date: Dec 2011 Location: Jacksonville , FL / Gatlinburg , TN
With my antenna wire rolled up in the radio box I can go about 100' . Like the rest said you probably wont be more than 10' away anyway if your crawling .
02-05-2012, 01:52 AM | #8 |
Quarry Creeper Join Date: Jul 2011 Location: Seattle
I just jammed mine inside my project box, and I can still easily run the length of the local football field with no noticeable issues. Keep it inside and protected is the way in my mind with 2.4Ghz.
do you really need a receiver antenna - Similar Threads | ||||
Receiver Antenna | Wavekatcher | Axial Wraith | 2 | 10-09-2011 04:51 PM |
Spektrum receiver antenna problem | cartronicshn | Electronics | 11 | 06-11-2010 09:09 AM |
Receiver antenna in scale rig | deephis46 | General Scale Talk | 14 | 08-13-2009 01:27 PM |
relocate receiver wire(antenna) | hdking46 | Electronics | 3 | 03-20-2007 11:13 PM |
Receiver antenna mounting | rockcrawler304 | Newbie General | 7 | 11-30-2005 10:55 PM |
