Thread: I get no low speed control when going down steep hill
Old 02-15-2012, 01:53 PM   #1
Default I get no low speed control when going down steep hill
I cant remember if I was able to get that real low speed crawl down a steep hill before, but when I give it the tiniest amount of throttle, gravity takes over and my wraith just starts to roll down the hill fast. The drag brake works fine on those steep hills, it has a nice slow speed drag brake. I have a tekin rs and a 13.5 tekin motor. Is there an issues here? what can my problem be?
davidq19 is offline   Reply With Quote
Old 02-15-2012, 04:26 PM   #2
Default Re: I get no low speed control when going down steep hill
what does everyone elses wraith do when you're on a steep hill going down and you give it a small amount of throttle?
Old 02-16-2012, 01:20 AM   #3
anyone?
Old 02-16-2012, 07:34 AM   #4
Sounds like you need a castle link to turn up your drag brake. My rtr was set at 50% from the factory
diesel kawboy is offline   Reply With Quote
Old 02-16-2012, 09:11 AM   #5
i have it turned up all the way through hotwire. i thought drag brake is for when i let go of the throttle and have it the trigger neutral. what effects the low speed control when going down something?
Old 02-16-2012, 09:33 AM   #6
I'm running the same motor and esc and i dont have this problem. but i changed my drag break with the buttons on the esc.
2500hdon37s is offline   Reply With Quote
Old 02-16-2012, 12:51 PM   #7
Hmm I wonder what could be wrong, what Throttle profile do you have yours set at?
I get no low speed control when going down steep hill - Similar Threads
Mud Water Steep Hill Descent at Devils Backbone - SCX10 Dig RockForce Highlift AX10 boolean21 Scale Videos! 0 06-26-2011 11:15 AM
Low End Control with Losi brushless?? jlanders001 Losi Micro-Rock Crawler 7 11-02-2010 11:50 PM
single speed setup vs. speed control traxxas junky Electronics 18 08-28-2007 11:28 PM
steep hill climb clodstall Videos! 5 07-09-2007 09:15 PM
My Highlift steep hill climbs... 96ram85chevy Videos! 8 10-16-2006 03:53 AM
