02-26-2012, 02:26 PM | #1 |
Pebble Pounder Join Date: Feb 2010 Location: Rochester, NH
| Wraith wheel weight
Is anybody running weights in the wheels? For all around use. I have new beadlocks and tires coming. I was thinking about 2oz in fronts nothing in back due to battery weight. |
02-26-2012, 02:35 PM | #2 |
| Re: Wraith wheel weight
have you upgraded your servo or are you rockin the stock one? each of my front tires weighs aprox 1lb. i have a 360oz servo. for all around id say total weight of about 8oz in the front and nothing in the rear. i use mine for crawlin only.
02-26-2012, 03:15 PM | #3 |
| Re: Wraith wheel weight Box stock for now until things break. Replace as needed.
02-26-2012, 03:19 PM | #4 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
I had 2 full wraps of lead when I started. Probably close to 4.5 oz in each front tire. Crawled pretty good. Put a brushless in and took all the weight out.
02-26-2012, 03:21 PM | #5 |
That servo is pretty weak. I'd stay away from adding weight until you get a better servo. Any weight with the stock one is asking for failure. Even going from stock wheels and tires to aluminum wheels and tires is a push for that servo
02-26-2012, 04:12 PM | #6 |
Rock Crawler Join Date: Apr 2009 Location: bend
I am running 4 ounces in each front tire and nothing in the back. Seems to work good.
02-26-2012, 04:21 PM | #7 |
Pebble Pounder Join Date: Oct 2011 Location: loveland
move battery to the front that is a big help! i got my kit cracked the beer open and glued the tires without putting anything in the front, new tires and wheels on the way but i know for sure i will be adding weight!
02-26-2012, 04:30 PM | #8 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
im running about 4.5 to 5 oz in the front about 2oz in the rear and does awesome to me in my opinion.
02-26-2012, 04:52 PM | #9 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
| Re: Wraith wheel weight |
02-26-2012, 05:09 PM | #10 |
RCC Addict Join Date: May 2010 Location: Midwest
I'm running about 4oz in each wheel and it seems to slow down my Savox 1268mg.. I know there are stronger servo's out there but, This one must be about 275oz-300oz at the 7v I'm running it at. Anyone else notice the servo performance decrease when adding weight in the wheels? |
02-26-2012, 05:41 PM | #11 |
Rock Crawler Join Date: Sep 2011 Location: FNQ Australia
Here's another way of weighting the truck . I wasnt keen to add weight to my stock tyres and wheels so I left them as is and I added weight to my axles . I run a 17.5T in one of my rigs and this avoids the severe backlash you can give your drivetrain when you run a maximum drag brake , no extra strain on servo either . Its easy to change the weights when you need or remove them altogether , only downside is the looks ! Gotta get a tidy box to put the lead in.
02-26-2012, 06:58 PM | #12 |
RCC Addict Join Date: May 2009 Location: Weston
I'm running 3 oz. in each front and 2 in each rear. Perfect setup for me.
02-26-2012, 07:59 PM | #13 |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
x2 on 3 ozs
02-26-2012, 09:43 PM | #14 |
I'm running 3.5oz front and 3oz rear right now with either 5000mah 2s or 3s 2250mah in stock rear location. Works good so far.
02-26-2012, 10:45 PM | #15 |
Quarry Creeper Join Date: Jan 2009 Location: pacific north west
3.5 front 1.5 rear
05-09-2012, 11:09 PM | #16 |
Rock Stacker Join Date: May 2012 Location: Tacoma
I used the self sticking weights from a tire shop .and put 2.75 on each front and 1oz on the rear wheels , and attached .50 on the front housing . That improved it`s performance on loose uphill dirt.
05-10-2012, 12:16 AM | #17 |
Newbie Join Date: Mar 2012 Location: Amarillo
9oz each rear and 3.5oz in each front.
05-10-2012, 01:04 AM | #18 |
RCC Addict Join Date: Feb 2012 Location: UK
I added two full strips of weight to each front tyre. I have the battery in the back still. Seemed to crawl a lot lot better and tip far less. |
05-10-2012, 11:36 AM | #19 |
RCC Addict Join Date: Nov 2005 Location: Utah
I think i ended up at 7 oz each front and 3.25oz each rear. Battery up front as well. Really stable rig.
05-10-2012, 11:42 AM | #20 | |
| Re: Wraith wheel weight Quote:
Wraith wheel weight - Similar Threads | ||||
How & Where To Add Weight to my Wraith? | Tiger 88 | Axial Wraith | 5 | 02-20-2012 08:16 PM |
Wheel weight Vs Axle weight. | Simon.O. | General Crawlers | 33 | 02-15-2010 07:01 PM |
Wheel weight or diff weight? | PipeDreams | Tires and Wheels | 4 | 11-06-2008 05:20 PM |
Wheel weight vs. chassis weight ratio OR spung/unsprung bias | solomon7 | Tires and Wheels | 15 | 08-02-2008 06:26 PM |
