02-27-2012, 05:21 PM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: Silverton
| FYI on punisher shafts
I changed the transmission out pit shaft to the Robinson Racing one piece unit and the MIP drive shaft was about 1 inch to short so i ordered the punisher shaft from RC4wd and since they were BO on the size i needed i got a longer one and cut it down to size. These are steel and easy to cut and file the ends on and drill for cross pins. I ended up with a nice heavy duty trans and drive shaft that i don't think well break. The stock clutch lasted about 30 minutes of driving so i installed the RR traxxas slash unit with a 54 t 32p steel gear and huge clutch. I will post some pictures as soon as it is back together. |
FYI on punisher shafts - Similar Threads | ||||
Punisher shafts | ElOriginal | Tamiya CR-01 | 2 | 06-16-2009 04:31 AM |
Punisher Shafts | shawn_081988 | Newbie General | 14 | 07-01-2008 07:33 PM |
Punisher Shafts for AX-10 | Flash | Axial AX-10 Scorpion | 20 | 03-29-2008 09:28 PM |
punisher shafts | Breaker 1-9 | Tamiya Txt-1 and Juggernaut | 5 | 11-07-2007 10:11 PM |
