03-06-2012, 11:24 PM | #1 |
Newbie Join Date: Jan 2012 Location: victoria
| wraith shocks.
hey guys, just have a question about shocks. I want to upgrade the shocks on my wraith and I am wondering what people are using. I'm not too wrried about scale looks, more about performance. Has anyone tried the traxxas big bores? Any input would be much appreciated |
03-06-2012, 11:30 PM | #2 |
Quarry Creeper Join Date: Feb 2012 Location: SAN DIEGO
| Re: wraith shocks.
I am amazed at the travel I'm getting with the G-Made 124mm Zero shocks. Only limit is the frame.
03-06-2012, 11:42 PM | #3 | |
| Re: wraith shocks. Quote:
03-06-2012, 11:47 PM | #4 |
| Re: wraith shocks.
Guess it really depends on what you want to do with it then? Harley would you say articulation is not so important if climbing is your main objective? I'm wanting to lower my truck cause it's soo darn top heavy,but droop kit seems to severely shorten my travel. Is this acceptable trade off? I only plan to crawl with it. Thanks! |
03-07-2012, 12:23 AM | #5 |
Rock Stacker Join Date: Mar 2009 Location: Basement of Coyote Hobby
| Re: wraith shocks.
Crawling is for babies! (Madram11) Youtube it!
03-07-2012, 12:49 AM | #6 |
| Re: wraith shocks.
Lol. I think that guy is a spaz. So do most in the 1:1 world. Pretty sweet vids though for sure. And his engine sounds like sweet music. I'm more into the technical aspect of it. Check this dude out! Coleworx Built YJ on Highway Trail, Farmington, NM 2010 - YouTube |
03-07-2012, 05:36 AM | #7 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
I think it's pretty obvious your choice depends on what you're looking for in your truck. You making it stock setup? Then you can go aluminum Axial 72-103mm, direct fit. Pro lines are a good choice (I just bought some to try). Stock XR10 shocks are nice and smooth. You can put whatever on it, all depends on what you're looking for.
03-07-2012, 06:14 AM | #8 | |
RCC Addict Join Date: Feb 2011 Location: York
I run the Traxxas Big Bore rears on my truck and while it flexes well, it soaks up the bumps and whoops. For me the 95mm Proline scalers really limited travel to the point of an obvious sacrifice in crawling. If you're tipping the balance toward the speed aspect, then the 3.5" (89mm) traxxas would be a good place to start. The length of the front powerstrokes will definitely shorten things up but it will let you run your mounts in the original locations and the extra oil capacity is great and completely necessary on a big boy like the Wraith. The 95mm Proline Scaler Shocks just don't have the fluid capacity to resist fade. RJ | |
03-07-2012, 10:56 AM | #9 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
| Re: wraith shocks.
I'm running XR10 shocks and I let em sag a little. soaks up bumps well, will still articulate if I need em to. The extra travel helps soak up hard landings.
03-07-2012, 11:02 AM | #10 |
Quarry Creeper Join Date: Oct 2010 Location: denver
| Re: wraith shocks.
i got the big bores on front and rear and so far im happy |
03-07-2012, 11:16 AM | #11 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
| Re: wraith shocks.
What springs on the Big Bores? I have a set of 4 Big Bores sitting in my drawer. Might give them a try. |
03-07-2012, 12:11 PM | #12 |
Quarry Creeper Join Date: May 2008 Location: malvern
| Re: wraith shocks.
Does anyone know the length of the pro-line powerstrokes for the rear of the slash.
03-07-2012, 01:46 PM | #13 | |
I run the stock wraith springs. | |
03-07-2012, 01:57 PM | #14 |
| Re: wraith shocks. |
03-08-2012, 01:49 AM | #15 |
| Re: wraith shocks.
Proline 4x4 Slash rears all the way around and a droop kit. For me! But I prefur to use a lead foot. Stick with a 2.2 comp rig(crawling up anything) , scale 1.9 rig(spots you wuold take your real street rig) the wraith is a rock racer(you can make it get ther but it might take some more wheel speed to get ther) I'll get off the soap box now Seen that vid Last edited by strykerjoe; 03-08-2012 at 01:54 AM. |
01-16-2016, 01:12 AM | #16 |
Newbie Join Date: Jan 2016 Location: Mount Perry
| Re: wraith shocks.
I have a question about making due with the stock shocks and how to keep them from throwing up all its fluid out the cap. I was wondering if a little pipe tape/thread tape on the shock body threads would help. I planned on trying it anyways, just wondering if anyone's gave that a shot yet.
01-16-2016, 01:46 AM | #17 |
| Re: wraith shocks.
Eventually, ill be looking at how the the Pro-Lines compare to the Kyosho Velvet 105mm's. I'm looking for an all-rounder, more towards crawling. I'm going brushless(roc412 3100 with 2 speed) if that matters. I'm new to this, but im sucked into it real good, lol. I take a lot of pride in my work and im soaking up all the details you guys throw at me. The combined experience on this forum is mind boggling.
01-16-2016, 05:49 AM | #18 |
RCC Addict Join Date: Feb 2008 Location: your back yard
| Re: wraith shocks.
I've used tape with some success but find it to be a pain with so little area. Even with fixing the leaks I don't stick with the stock shock on any rig other then a bash truck. Like all the other weak links that we change and fix it's best to just upgrade the shocks. I plan to use the powerstroke on my build. Good luck |
01-16-2016, 07:49 AM | #19 | |
Newbie Join Date: Dec 2015 Location: illinois
I keep mine from leakimg by using a decent amount of liquid elctrical tape on the threads during assembly. Wipe off the excess and let it dry a day before use. Bone dry after a full season of use. Plastic bodies and caps no problem. | |
01-16-2016, 08:50 AM | #20 |
| Re: wraith shocks. Cool, I figured there was a way to make due for now, much appreciated |
wraith shocks. - Similar Threads | ||||
wraith shocks? | rcdriver199 | Axial Wraith | 11 | 12-12-2011 07:22 PM |
what shocks are on this wraith | hdwheelieking1 | Axial Wraith | 6 | 09-29-2011 07:23 AM |
