03-11-2012, 10:57 PM | #1 |
Quarry Creeper Join Date: Mar 2009 Location: algonquin
| ax-2 drag brake?
so i recently got my axial wraith, i love it but..... its say the ax-2 ESC has a drag brake, but for some reason my wraith will roll off everything if i take my finger off the throttle. am i missing something? btw my wraith is the RTR version, and i am using a 4700mah stick pack thanks guys |
03-11-2012, 11:49 PM | #2 |
Quarry Creeper Join Date: Feb 2012 Location: AZ
| Re: ax-2 drag brake?
Mine is the RTR version and if I'm on carpet going fast and let off the throttle, it almost lifts the rear wheels. Sounds like yours isn't programmed with the drag brake. There's instructions on Axial's website on how to manually program it without the Castle Link.
03-12-2012, 09:00 AM | #3 |
Quarry Creeper Join Date: Feb 2008 Location: Montreal, Canada
get a caste programming field card
03-12-2012, 10:56 AM | #4 | |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: ax-2 drag brake? Quote:
Oh and mine is kit Wraith not RTR so I am in the build mode still too. | |
03-12-2012, 11:20 AM | #5 |
Quarry Creeper Join Date: Aug 2005 Location: Spokane
Even with the castle link it only lets you set it to 100% and it still rolls off of rocks and hills. You cant program it like the sidewinder to 150% or more.
03-12-2012, 04:47 PM | #6 |
maybe i am just to used to my novak esc in my other rigs
03-12-2012, 06:18 PM | #7 |
Follow the instructions in the link below. I just set mine to 100% and the drag brake is strong. Axial's website says that the default setting is 100%, which is wrong. It comes set at 50%. Now on carpet, it will do a nose wheelie when I let off the throttle. Give it a try. It only takes a couple minutes to go through the settings. Axial AE-2 ESC Set-up and Programming |
03-13-2012, 02:23 AM | #8 |
i did that already. i guess its just not as strong as i am used to. thanks though
11-07-2012, 03:16 AM | #9 | |
RCC Addict Join Date: Aug 2012 Location: Philippines
| Re: ax-2 drag brake? Quote: "The page you were looking for doesn't exist." Because it is here now: Axial Racing - Axial AE-2 ESC Set-up and Programming | |
11-11-2012, 07:53 AM | #10 |
I reprogrammed the ax2 in my wraith and see no improvement. Still rolls off everything.
11-11-2012, 08:22 AM | #11 |
Pebble Pounder Join Date: Dec 2011 Location: Ohio
The stock motor is poop, get yourself a nice brushed motor and it will hold better. Mind you its not the holmes hold but it works well
11-11-2012, 08:41 AM | #12 |
Quarry Creeper Join Date: Jul 2012 Location: Alpharetta, GA
| Re: ax-2 drag brake? |
11-11-2012, 09:12 AM | #13 |
Pebble Pounder Join Date: Apr 2012 Location: Apple Valley MN
I have a Ridgecrest (has the same ESC and motor as the Wraith) and I programmed mine yesterday with the Castle link and set the drag brake to 100%. Much better on the steep stuff.
11-11-2012, 10:31 AM | #14 |
Is the ridgecrest's gearing different than the wraith? I threw an old 27t motor with stronger magnets in the truck, still not seeing much rolling resistance. Wondering if this esc is just bad...? Last edited by gbean; 11-11-2012 at 10:33 AM. |
11-11-2012, 11:35 AM | #15 |
Both the Ridgecrest and Wraith manuals show the same gearing (I downloaded the pdf files from Axial), but the manual for the Ridgecrest is wrong- mine came with 87/20 and now I'm running 87/18 and still need to slow it down a bit (stock motor is 20T). Manual shows 80t spur. I ordered a cheap 27T motor for kicks and see if that helps a bit.
11-11-2012, 01:20 PM | #16 |
Then next step is an esc?
11-13-2012, 10:33 AM | #17 |
Can you borrow a different ESC and see if that helps? Possible the ESC is bad, but if others say the stock motor is weak I's probably replace that first.
11-13-2012, 10:39 AM | #18 |
Pebble Pounder Join Date: Mar 2011 Location: Aurora, CO
What gearing and motor are you currently running without an effective drag brake? Marcus |
11-13-2012, 01:14 PM | #19 |
Im running 17/80 gearing. Drag brake doesnt exist on the stock motor, other motors I've tried are old non crawler specific. a 27t motor showed slight improvement. I dont think the ESC is bad, it only has 4 fairly easy hours on it... I am going to try a HH 16t (THIS ONE) |
11-13-2012, 02:57 PM | #20 |
The AE-2 and Sidewinder on the stock 20t motor are really about the same in terms of braking power. I stuck a 55t stock Axial motor in and it was a big difference. The AE-2 set at 100% stops the Wraith on my test ramp, but just barely. If you nudge it you can get it to roll a little. The Sidewinder with 213% brake (crawler brake) holds the Wraith tight and the wheels won't move at all.
ax-2 drag brake? - Similar Threads | ||||
drag brake | snohiker | Axial Wraith | 4 | 11-21-2011 07:46 PM |
I need more drag brake... | Der Kampfer | Electronics | 26 | 01-19-2011 11:27 AM |
scx10 honcho no need for DRAG BRAKE?... already has drag... | yellowpasta2000 | Axial SCX-10 | 21 | 01-23-2010 09:28 AM |
drag brake | ax10 | Newbie General | 5 | 03-23-2009 05:11 AM |
Throttle / Drag Brake / Brake Question | phatchantz | Newbie General | 5 | 05-19-2008 11:57 AM |
