03-19-2012, 05:52 AM | #1 |
Newbie Join Date: Feb 2012 Location: Tacoma
| Can't steer right
So I just finished building my Wraith and when I went to take her for a test drive today I was unable to turn to the right. When I hold it off the ground it has no problem turning left or right but as soon as it hits the dirt or concrete I lose all ability to turn to the right. Has anyone seen this before or know how to fix it?
03-19-2012, 06:00 AM | #2 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
| Re: Can't steer right
We need a little more info. What kind of servo and electronics are you running? I'm assuming since you said finished building you started with the kit and not the rtr with the rtr electronics? |
03-19-2012, 06:07 AM | #3 |
Its a Futaba S3003 Servo and a Castle Creations Sidewider SCT ESC. Yes it was a kit build. Im also runing a 2 Cell LiPo
03-19-2012, 06:39 AM | #4 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
| Re: Can't steer right |
03-19-2012, 06:44 AM | #5 |
is there any specific servo and bec you would suggest? I'm currently deployed with the military so parts are hard to get and swap if they don't fit.
03-19-2012, 07:19 AM | #6 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
Any servo with 200oz or more is wht you need, and it just needs to be a 1/10 servo, they will all fit! As for the BEC I would suggest the Castle Creations 10 amp BEC. And thanks for what you do for our country |
03-19-2012, 07:30 AM | #7 | |
| Re: Can't steer right Quote:
This is what I use... TowerHobbies.com | 37954S Hitec HS-7954SH High Voltage Ultra Torque Dual BB Servo TowerHobbies.com | 010-0004-00 Castle Creations CC BEC 10A 6S Switching Regulator | |
03-19-2012, 08:34 AM | #8 |
Hey its no problem, it helps pay for my new found addiction. As far as servos go do I absolutely need one that strong? I am actually building this Wraith in a more race oriented manner with the ability to crawl but mainly focusing on speed.
03-19-2012, 08:45 AM | #9 |
Rock Stacker Join Date: Dec 2011 Location: Fresno
YES! you could probably get away with something in the 120 oz range like the stock RTR AS-1 for just running it around in parking lots or light crawling, but i definitely recommend a servo with 200+ oz of torque. And make sure you change out those stock steering links if you haven't already because no matter how strong your servo is, if the flimsy plastic links bend while your servo is turning it, your rig will still go no where. Don't ask me how I know.
03-19-2012, 08:58 AM | #10 |
Quarry Creeper Join Date: Feb 2008 Location: Montreal, Canada
or you can do some dirt oval runs, as long as it turns left hehe seriously, if you run a BEC i would also go with a high voltage servo just as Turn'Nburn mentionned! |
03-19-2012, 09:32 AM | #11 |
If price is a concern and you don't mind ordering from Hobbyking, here is a good one... HobbyKing R/C Hobby Store : BMS-2514 Coreless Digital Alloy Gear Servo - 25.5kg / 0.14s / 7.4V (High Voltage) |
03-19-2012, 10:00 AM | #12 |
well I just pulled the wheels off and the servo is totally shot going right.
Can't steer right - Similar Threads | ||||
help with 4w steer | bboybean | Newbie General | 12 | 02-19-2010 01:46 PM |
Will Vanquish Axial High Steer Steering Knuckles make my truck steer tighter? | blue bronco | Axial AX-10 Scorpion | 3 | 08-09-2009 12:30 AM |
How to steer it? | akres15 | General Crawlers | 13 | 03-08-2009 11:26 AM |
No Steer!! | jeepguy | General Crawlers | 6 | 09-16-2005 02:32 PM |
