04-11-2012, 02:23 AM | #1 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
| 1.9 Wraith build
I got a used Wraith chassis from a buddy and since I had some SCX axles I decided to build a scaler Wraith. Here's a list of parts used Wraith Chassis SCX axles and trans Pro-line Titus wheels 1.9 Pit Bulls VP CMS servo mount DP Customs 3 link axle truss Pro-line Power Stroke scale shocks here's some pics Still need to figure out a really long rear driveshaft and slap some electronics in her. I may play with the cage a little and add a Dinky tray for the rear. Any thoughts would be appreciated |
04-11-2012, 02:33 AM | #2 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
| Re: 1.9 Wraith build
Junfac do a 140mm long drive shaft.
04-11-2012, 07:38 AM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: The underground
What links did you use? I'm building one my self out of spare parts from my junk pile
04-11-2012, 09:49 AM | #4 |
Rock Crawler Join Date: Nov 2008 Location: missoula
Nice i tried but just didnt work out couldnt get steering correct so went back to wraith axles for daughter left 1.9 tires it looked so good to.
04-11-2012, 03:12 PM | #5 |
Thanks I'll look for those shafts. I made my links I can measure them for you if you want.
04-11-2012, 06:20 PM | #7 |
Newbie Join Date: Aug 2009 Location: SAGNASTY
Looks good! I picked up another wraith today for a 1.9 build. How do you like the pit bulls and servo mount?
04-11-2012, 08:25 PM | #8 |
The Wraith chassis looks soooo much better with AX axles and 1.9's compared to stock. |
04-11-2012, 09:48 PM | #9 |
What are u guys using to steer i had a big problem trying to get my daughters to steer even tried a panhard setup
04-12-2012, 04:04 AM | #10 | ||
| Re: 1.9 Wraith build Quote:
I agree the Wraith looks much more scale with these axles. I'd like to narrow a set of Wraith axles, offset front & center rear. The tires feel great haven't run them yet. The VP mount is nice. I simply added an old TXT part to make the panhard mount. It seems to work fine. Quote:
I'll snap a pic of the front end and add it to this post. What was your setup that didn't work? | ||
04-12-2012, 06:40 PM | #11 |
I used a cms no panhard bar just on the frame horrible bump steer. My axles not sure what they were from look like axial scorpion but have no way of mounting a servo on the axle like the scorpion. I didnt give up i got another chassis i liked the 1.9 look yours is really nice.
04-12-2012, 08:30 PM | #12 |
| Re: 1.9 Wraith build |
04-15-2012, 11:05 AM | #13 |
Quarry Creeper Join Date: May 2011 Location: Ak
I ended up using a 4 link kit for an axial scx10 dingo to get a reasonable Wb. Still a little long for my taste. Wb8 drive line kit has plenty of options to get the length needed for the rear drive line. IMHO you'd have to chassis mount the steering servo to tuck the front axle in enough to get the front wheels into the wheel well area. I had to do some trial and error shimming of my upper links to get enough clearance for my servo to tuck into the gap in the front of the chassis. Last edited by SC Convert; 04-15-2012 at 11:09 AM. |
04-15-2012, 07:07 PM | #14 |
So if i use the vp panhard setup and csm kit it should work fine for steering???? I want to do this again i have another chassis to start with.
04-16-2012, 08:36 AM | #15 |
I've never used the cms setup yet so I can't chime in. I do know it is a trick to get the servo positioned on the axle so it clears the chassis on full compression. This is how mine sits at the moment. No 1.9's till I shorten the front and chassis mount my steering servo. |
04-16-2012, 08:51 AM | #16 |
Pebble Pounder Join Date: Dec 2009 Location: Silverton
I take any long pipe i have and chuck it up in the drill press and then cut it to the size i need. I had four Mip drive shafts and i need 145mm for the rear shaft because i used the AX10 transmission so i cut two male shafts and mig welded them together and ended up with a rear shaft . I just rock tested my SCX10 wraith yesterday and it out crawls my AX10 i think. It is so stable and well go where the stock wraith is to wide. I have both 1.9 wheels and 2.2 for it.
04-16-2012, 08:59 AM | #17 |
I love the Wraith axles but wow! It looks really awesome with narrow axles and 1.9's! |
04-17-2012, 06:34 PM | #18 |
Here are the link lengths for those interested. Rear is using the axial 4 link truss mount. lowers: 4 5/8" -118mm eye to eye uppers: 118mm eye to eye Front using my own truss 3 link mount lowers: 99mm eye to eye upper: 80mm eye to eye I was able to use Stampede shafts front and rear. Then I got all the electronics together and tested them with good results. Then I got it all installed and nothing works. The RX isn't getting power from the new Eiger ESC. Not sure what the deal is, but it's upsetting. |
05-02-2012, 08:42 PM | #19 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Bump, Whats the wheelbase? I wish all the 1.9 wraith builds were in the same place... |
05-02-2012, 10:40 PM | #20 | |
RCC Addict Join Date: Sep 2007 Location: Western ND, Bakken central
1.9 Wraith build - Similar Threads | ||||
My Wraith build | SFT2 | Axial Wraith | 35 | 05-12-2013 02:58 AM |
My wraith build so far | wraith89 | Newbie General | 3 | 02-02-2012 09:44 AM |
My new Wraith build !!! | RCRockstar | Axial Wraith | 9 | 01-31-2012 11:27 PM |
my wraith build | Slap204 | Axial Wraith | 0 | 11-14-2011 10:47 AM |
Wraith build | pwrwgn2000 | 2.2 Scale Rigs | 2 | 10-17-2011 07:27 AM |
