05-09-2012, 11:59 AM | #1 |
Rock Stacker Join Date: Mar 2008 Location: 734
| To those using the velineon system
Did your motor fit right in the chassis or did you have to trim some of the link mount a little? Mine will not allow the trans to bolt flat to the skid Sent from my tardis using Tapatalk |
05-09-2012, 12:04 PM | #2 | |
RCC Addict Join Date: Dec 2008 Location: Sonora, CA
| Re: To those using the velineon system Quote:
I was planning on using the same system. I did how ever use one on my Foff build using a SCX10 chassis. I had to make a spacer for under the Trans to create the clearence it needed. Due to the similar skid type design I think that maybe your easiest solution to your problem. | |
05-09-2012, 01:16 PM | #3 |
I thought of that too appreciate the input ! Sent from my tardis using Tapatalk |
05-09-2012, 02:05 PM | #4 |
Rock Crawler Join Date: Nov 2006 Location: Holland
| Re: To those using the velineon system |
05-09-2012, 02:10 PM | #5 |
Rock Crawler Join Date: Jun 2007 Location: Working in my dream RC workshop and remodeling my entire home.
I got my VXL to somehow fit without doing any mods. I did kind of stuff it in there without taking apart the whole truck. I am doing a total rebuild on my truck now (mainly so it will withstand the crazy speed of said VXL motor), so I'll have to see what is going on in there for sure.
05-09-2012, 02:15 PM | #6 |
Rock Crawler Join Date: Dec 2011 Location: Blacksburg
take the black plastic cap off of the rear and it should fit no problem.
05-09-2012, 02:47 PM | #7 |
I'll assume the cap is just there for looks and to protect the connections right Sent from my tardis using Tapatalk |
05-09-2012, 02:49 PM | #8 |
| Re: To those using the velineon system It protects the whole end of the motor.. It also covers the end of the shaft and bearing.. Which should be sealed up with some sort of tape.. Cover keeps the tape fresh as well.
05-09-2012, 02:49 PM | #9 |
Quarry Creeper Join Date: Dec 2009 Location: Nacanowhere Texas
Yeah I took the back cap off of mine and it fits perfectly
06-01-2012, 05:04 AM | #10 |
Quarry Creeper Join Date: Apr 2012 Location: Marietta
Does that black cap have anything to do with water resistance? Or just to keep dust and crap out!
06-01-2012, 11:44 AM | #11 |
I will assume its there to protect the connections and to keep stuff out of the bearing in the back but if you seal that up I'd imagine itd be fine Sent from my tardis using Tapatalk |
06-03-2012, 12:09 AM | #12 |
Quarry Creeper Join Date: Sep 2011 Location: Columbus, Ohio USA
The cover does nothing IMO when I took it off I had to dig the mud out from behind it. I put a sticker over the bearing fwiw I dremeled away some of the chassis to clear the motor, it can be forced w/o trimming but the skid will be a little tweaked. Cheers Speed |
To those using the velineon system - Similar Threads | ||||
Velineon system?? | smm_cbf | Electronics | 4 | 06-29-2009 11:27 PM |
