Thread: wraith help
Old 05-14-2012, 08:02 AM   #1
Default wraith help
Bought a kit, built it. put a novak timbuk2 set up in it. now that its ready to run im confused. When i hit throttle rear wheels want to go in reverse. front wheeels go forward. Now when i hit reverse it goes in reverse. Is it possible that the rear axle gears could be reversed? Is it a timbuk2 programming issue(which i doubt). Any thoughts would be super . thanks
griz is offline   Reply With Quote
Old 05-14-2012, 08:48 AM   #2
Default Re: wraith help
I'm guessing the ring gear and locker are installed backwards.
Consult your directions to verify.
btoungette is offline   Reply With Quote
Old 05-14-2012, 08:51 AM   #3
Its not a problem at all just take the ring gear out of the rear axle and flip it around and you will be good to go
Sent from my DROIDX using Tapatalk 2
snail78 is offline   Reply With Quote
Old 05-14-2012, 10:36 AM   #4
Thanks guys thats what it was.
wraith help - Similar Threads
Wraith Skins for m_energy's Wife's Wraith Krawler Konceptz Paint and Body 2 10-18-2011 11:29 AM
