Thread: Knuckle flange pipe help
Old 05-16-2012, 09:16 PM   #1
Default Knuckle flange pipe help
So I finally got new knuckles and chubs today after breaking the stock knuckle on the first battery pack. When the knuckle broke I lost one of the flange pipes and the screw. After searching here I was under the impression that knuckles came with all necessary hardware, however, that isn't the case. Without the flange pipe I can't tighten the screw and there is major floppiness in the wheel. I know the LHS won't carry them. I keep breaking parts (or having them be defective out of the box) and haven't even driven through a full battery pack yet, having to wait until funds are available to order a new part. This is my first RC and I'm so frustrated!!! (on the plus side, I have had plenty of time to do cosmetic mods and make accessories) There is a local club drive on Saturday and I would really like to go. There is no way they could be shipped here in time, is there a compatible part from another company that the LHS might carry? Or something from the hardware store that might work? Can I go all MacGyver on it? I was thinking duct tape around the top of the screw and a plastic washer? Help!
ApeMac15 is offline   Reply With Quote
Old 05-16-2012, 09:20 PM   #2
Default Re: Knuckle flange pipe help
Check your parts tree. I found something on my tree that worked.
sixhundred71 is offline   Reply With Quote
Old 05-16-2012, 09:27 PM   #3
Axial Flanged Pipe 3x4.5x5.5mm 4pcs. AX30450 AX10 | eBay
Not sure where you are but ToadzRC is great!
HPI makes them: http://www.ebay.com/itm/HPI-A838-STE...9#ht_500wt_922
ZippoMan is offline   Reply With Quote
Old 05-17-2012, 12:51 AM   #4
Yep, parts tree number AX80018-3. These are plastic replacements and the first ones ZippoMan mentions are metal.
Solitaire is offline   Reply With Quote
Old 05-17-2012, 01:26 AM   #5
or order from a vendor here NO SLOP king pin bushings. AX10, Berg, SCX10
jvella is offline   Reply With Quote
Old 05-17-2012, 05:41 AM   #6
Ooo, found it. Thanks!
Knuckle flange pipe help - Similar Threads
CKRC knuckle, VP knuckle, Super 300? DeadlySwan EnRoute Berg 5 12-03-2011 11:07 PM
Window Flange? kc092755 1.9 Scale Rigs 0 06-16-2011 04:36 AM
axle flange.......... bob1961 Axial AX-10 Scorpion 6 11-14-2008 05:05 AM
Axial Flange Pipe 3x4.5x5.5 Robbob Axial AX-10 Scorpion 3 05-01-2008 09:58 PM
