06-15-2012, 08:55 AM | #1 |
Rock Crawler Join Date: Oct 2011 Location: Lake Worth
| Waterproof Pro4 with Corrosion X?
I have been on YouTube and the search help on RCCrawler and can't find the person that made a YouTube video of waterproofing a Pro4. He goes into detail about disassembly and using the product. I have also searched the motor/esc help section at the top of the page and couldn't find it. Can anyone help me with the link? Thanks in advance!
06-15-2012, 05:43 PM | #2 |
Pebble Pounder Join Date: Sep 2011 Location: USA
Sorry I can't help find the video but I corrosionX mine. If you need help disassembling the motor there is a few YouTube videos for that. Completely disassemble motor then soaked everything in corrosionX. I moved parts around to make sure they got coated. I let them sit for couple days to drip off then wiped off excess corrosionX and assembled. I submerged my motor 6 times and no problems. Sent from my iPhone using Tapatalk |
06-15-2012, 08:33 PM | #3 |
| Re: Waterproof Pro4 with Corrosion X?
Thanks for the help I'll disassemble the motor and soak it. So you can clearly see the excess on the parts after taking them out of the Corrosion X?
06-15-2012, 09:51 PM | #4 |
It's clear but yes. You will see it stays wet and i recommend drying it off pretty good It's like a oily wd40. I even did my rx8 esc. That never got submerge but has been splashed. You really can't screw up. You could even get rid of the excess with compressed air. Sent from my iPhone using Tapatalk |
06-25-2012, 08:05 PM | #5 |
Thanks for that, it'll help me too. Going to do mine and it looks like corrosionx is really the only option for the sensor board... thinking of doing the sensor plug/port with dieletric grease, plastidip over it and plugging up the front screw mount holes with set screws. Yeah i'm a bit untrusting |
06-25-2012, 09:28 PM | #6 | |
| Re: Waterproof Pro4 with Corrosion X? Quote:
06-25-2012, 10:48 PM | #7 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
Anyone use any other water proofing methods on these? I need to do something to mine..
06-26-2012, 12:40 AM | #8 |
Newbie Join Date: Jun 2012 Location: frankfurt germany
can you use this on a brushed motor as well??
06-26-2012, 04:17 AM | #9 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
I am having a hard time finding corrosion x up here in northern Alberta. Wondering if any one knows if this will work the same. sent from my Galaxy SII using Tapatalk 2.0 |
06-26-2012, 11:56 AM | #10 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
X2^^^ Corrosion X is hard to find up here. If anyone knows of another similar product that works or another method say like plasti-dip or liquid electrial tape. I would rather waterproof it and forget about it then worry about has it been 6 months 9 a year and then go O s*** my motor is now dead. Please someone let us now as I know there has 2 be more then 1 way to waterproof this motor. |
06-26-2012, 12:35 PM | #11 | |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
So for us Canadians I say buy direct!! http://www.shop.corrosiontechcorp.co...pray-91002.htm | |
06-26-2012, 01:03 PM | #12 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
I found it at a Safety supply shop for Firefighting equipment.. I'm not a fire fighter, I just went in there looking for a strap for my hard hat and they had it on the counter. I'm in Nova Scotia Canada. the "Have Not" province. lol |
06-26-2012, 01:12 PM | #13 |
| Re: Waterproof Pro4 with Corrosion X? |
06-26-2012, 02:41 PM | #14 |
Yes I know I can get it direct but If there is another way that dosen't require reapplying after 6 months to a year that is the way I would prefer to go. Can anyone pipe in and say if you can use plastidip or liquid electrical tape for this motor.
06-26-2012, 03:50 PM | #15 |
06-26-2012, 04:19 PM | #16 |
Quarry Creeper Join Date: Dec 2009 Location: Honolulu
Another option, same effect as corrosion x. |
06-26-2012, 09:56 PM | #17 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
I pulled the sensor board out and sprayed it with three coats of conformal coating, reassembled it, and then sealed up the can with electronic safe silicone sealer. Basically fill in any gaps where water can get in and make sure you fill any extra threaded mounting holes with blue threadlocked set screws. I've had mine under water several times. I've also pulled the motor apart a couple times and it's completely clean and dry inside.
06-27-2012, 01:04 AM | #18 |
06-27-2012, 04:58 AM | #19 | |
Newbie Join Date: May 2012 Location: Fayetteville
--- I am here: http://tapatalk.com/map.php?doio2q | |
08-13-2012, 10:19 PM | #20 |
Pebble Pounder Join Date: Aug 2012 Location: repentigny qc
Waterproof Pro4 with Corrosion X? - Similar Threads | ||||
Boss 304 Wheels and Corrosion on the Inside | run2jeepn | Chit Chat | 24 | 11-13-2010 12:01 AM |
Where can I get Corrosion Block | goslo | Electronics | 2 | 03-04-2008 05:58 PM |
Corrosion X Spray | Troublemaker | Electronics | 4 | 10-12-2007 07:55 AM |
