07-20-2012, 02:02 PM | #1 |
Pebble Pounder Join Date: Sep 2011 Location: Between the thoughts of yesterday and the ideas of tomorrow
| Wraith with R1 axles
So I recently picked up a wraith chassis for a good price. I only need axles/diffs to tet this bad boy wreckin the rocks. So heres my question, DO I go with stock wriath axles or aftermarket ones. I found these and I was wondering how hard they would be to mount up. Any advice or input would be appricaited. Thanks G-Made R1 Front and Rear Portal Axle Set #GM51100*-*Axles*-*-Geartrain - Axles - Driveline*-*The Crawlers Store LLC |
07-20-2012, 02:11 PM | #2 |
Quarry Creeper Join Date: Nov 2011 Location: Plano,TX
| Re: Wraith with R1 axles
At one time not too long ago - I was looking at getting a R1 - what made me decide not to get it was the axles. Yes - the portal design is cool - BUT from everything I read (and I read every thread) - the little arms on the end of the dogbones are notorious for breaking off. Just my $0.02 Wraith axles are tough. |
07-20-2012, 02:16 PM | #3 |
Newbie Join Date: Jun 2012 Location: Alberta,Canada
Im mounting a set right now, took a break for some lunch, Ill post pics and my $0.02 when Im done
07-20-2012, 02:18 PM | #4 |
On the axles I posted I don't see what part your talking about
07-20-2012, 02:19 PM | #5 |
Driller1, I would like to see it. Also when your done if you like them, shoot me a message on the parts you used to mount them up. Thanks Last edited by Blades; 07-20-2012 at 02:29 PM. |
08-04-2012, 04:02 PM | #6 |
Pebble Pounder Join Date: Jan 2011 Location: Portugal
I have a wraith chassis with R1 axles and so far no problem with them. Itīs easy to mount them on the chassis, the only problem you may have is the steering servo, it cant stay in the axle. But itīs easy mount it in the chassis with a panhard bar You may see my project in De Redcat a Gmade R1, agora "O meu Zuki 2.2" |
11-04-2012, 08:59 PM | #7 | |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Wraith with R1 axles Quote:
11-05-2012, 04:06 AM | #8 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
Ive had R1 axles....keep the axial axles, whether they are scx10 or wraith axles....Way better!!! For the things I put my trucks through, R1's dont stand a chance.... Funniest thing is, even one of the biggrest crawler stores in the land, run scx10 axles on their R1 Chassis... |
02-16-2013, 12:58 PM | #9 |
Rock Stacker Join Date: Feb 2013 Location: North Texas
I installed r1 portal axles under my wraith with 4WS and I see no problem with the steering servos on the axles. I still have plenty of articulation room and that's with the droop kit installed to lower the chassis
02-16-2013, 01:21 PM | #10 |
Forgot to mention I also purchased the "R1 adjustable upper link mounts" from ckrc. Allows you to use the wraith links or something similar and eliminates the minor lateral slop movement the axles have. It will still require some minor modification of the links to get the right pinion angle to the transmission. I'm about to start that process on my when I get a chance.
02-28-2013, 06:20 PM | #11 |
Newbie Join Date: Jan 2012 Location: Hartford
I'm building the same exact truck right now out of spare parts I had kicking around. Wanted to make a junk basher for my nephew and these where the axles and chassis I had. If you can post some pics of it or a running video so I can see if i'm just better off getting a set of scx10 axles and scraping this idea. My r1 axles tho are upgraded with every part I could find for them including the CVD's
02-15-2014, 05:10 AM | #12 |
Quarry Creeper Join Date: Nov 2013 Location: California
* thread resurrection * I just put the R1 portals on my Wraith and they fit up pretty easily with stock links, wheels, etc. There is a bit of rubbing but nothing the Dremel can't fix. I especially like how the stock wheels fit up and stay tucked up close to the portal gear box. I'll never go back to the stock axles, that's how awesome the R1 axles work (and look) for my driving style. I'm not a go fast guy with $$$ power. Just running $10 brushed crawler motor and gear reduction box from RC4WD. The stock Axial axles are almost bullet proof. Never had any failures or problems. I just don't like the width & fat housing draggin' everywhere. Besides, it's fun to try something new & different. I'll post some up close photos or walk around vid later on. I was going to do a crawlin' video but the plastic Axial trans gears stripped out yesterday and LHS don't stock sheat So I'm SOL till Wednesday unless I can make an R2 trans fit. Last edited by GraniteBandit; 02-15-2014 at 06:46 AM. |
02-15-2014, 07:27 AM | #13 |
| Re: Wraith with R1 axles |
02-15-2014, 08:01 PM | #14 |
Newbie Join Date: Dec 2013 Location: Sacramento, CA
Iv always wanted to see the x1 axles on a rig :(
02-19-2014, 07:34 AM | #15 |
Just got my RTR Wraith rollin' on these Gmade portals. They're an easy swap with the stock links if you use the adjustable upper link mount (hop-up item). I really like the look and extra clearance. I'm going to go EZ on these axles and try to make them last. I've already fully roasted the Axial steering servo, motor & trans gears. Flex testing with stock shocks and mounting. As you can see, I'm still using the stock Wraith wheels/tires. I like how the wheels stay tucked up close but there was a bit of rubbing on the steering links so I had to make my own steering link. So far so good. |
02-19-2014, 07:40 AM | #16 |
This is kinda sketchy picture I know. This is front end. Rear end. This is that upper link mount (rear end) that makes the swap so easy. Some cones were added to keep the links from rubbing on the mount. The high pinion really keeps the drive-shaft angle to a minimum. This is stock drive-shaft. Last edited by GraniteBandit; 02-19-2014 at 07:13 PM. |
02-19-2014, 07:44 AM | #17 |
| Re: Wraith with R1 axles Last edited by GraniteBandit; 02-22-2014 at 05:22 AM. |
02-19-2014, 10:20 AM | #18 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Looks good so far.....
02-19-2014, 12:31 PM | #19 |
Newbie Join Date: Jan 2013 Location: nashua
Im building a Wraith from the ground up and was wondering about this. And if i remember the R1 axles are cheaper too.
02-19-2014, 07:01 PM | #20 |
To increase the steering angle with the Gmade R1 axles, I used the Dremel to remove a little material here. If you expect to run the stock Wraith wheels with the Gmade portal axles, you could have a clearance issue here. If you're using other wheels, with a different offset than stock, you won't have an issue. The Gmade portal axles come with a set of links and ball ends. For the front axle and retaining the stock Wraith links, I had to reverse the upper link mount to get a good pinion angle. Spacers were needed to clear the pumpkin. A short stack of washers could work just as easily. I went with the 7 degree c-hubs (hop-up item) and this is what you get. The width is about 10-1/2" with the Gmade portal axles and stock Axial Wraith wheels. |
