07-23-2012, 12:03 AM | #1 |
Quarry Creeper Join Date: May 2012 Location: Industry
| Ridgecrest to Wraith Conversion
Hello and Welcome. So a couple months back I started looking at crawlers and decided to pickup the new Ridgecrest to give it a shoot. During that time I picked up some wheels and tires while playing around with the gears to get some more speed out of her. Ended up getting the Traxxas Velineon system that really gave me the speed that I was looking for. However, this didn't satisfy the looks of the truck. After looking at the forums I really started to like the looks of the Wraith. And the search begins. Been on many sites finding the correct parts that are needed for the conversion. I was able to use just about everything but the frame from the Ridgecrest to go from this: To This: Now I'm still in the process of the build with many parts on its way. Hope you enjoy! |
07-24-2012, 08:59 PM | #2 |
| Re: Ridgecrest to Wraith Conversion
Added the Dinky Drop Tub and cut the side panels. Also moved the ESC to the rear for easy access. Plastic Dipped ESC for added protection even if its waterproof. |
07-25-2012, 03:30 AM | #3 |
Rock Stacker Join Date: Feb 2011 Location: NSW, Australia.
Nice. I was going to do the same with my AX10 Scorpion, but I unded up buying a used Wraith instead. Where did you buy the tub for the rear? |
07-25-2012, 07:12 AM | #4 |
Looks like you have the AX-10 transmission in there. The rear driveshaft doesn't have much engagement, better keep an eye on that. It'll twist REALLY easy.
07-25-2012, 10:38 PM | #5 | |
| Re: Ridgecrest to Wraith Conversion Quote:
Yes thats the AX10 tranny from the Ridgecrest. I am having a problem with the rear driveshaft not being long enough. The HR links that I have are giving me a wheel base of 14.5in where the stock Wraith is 13.5. Thats causing the shortness. I got MIP Wraith shafts in the mail today and I'm switching out the links with the Axial upgrade links on order. | |
07-25-2012, 11:13 PM | #6 |
Installed battery forward tray today. |
07-26-2012, 01:45 AM | #7 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
id invest in a rear driveshaft for sure x2
07-26-2012, 01:55 AM | #8 |
| Re: Ridgecrest to Wraith Conversion |
07-26-2012, 02:15 AM | #9 |
07-28-2012, 08:47 PM | #10 |
Well today I was able to get some time out on the trails. This thing is a beast! Lost a couple of screws that I forgot to threadlock but over all it was a great day. Heres a couple pics from today. |
08-06-2012, 01:07 AM | #11 |
Upgraded to a 3cell Lipo. Looking to upgrade soon. Just ordered the following. Vanquish Wraith Panhard Kit Vanquish Titanium Steering Links Kit Wraith, Ridgecrest, Vanquish Aluminum Axle Housings Front OR Rear Wraith, Ridgecrest Vanquish Aluminum 3D Differential Cover, Wraith or Ridgecrest Vanquish Aluminum Axle Trusses Wraith, Ridgecrest (2) [4172] Vanquish Axle Trusses: Vanquish Differential Bearing Caps Vanquish Wraith/Ridgecrest Link Mounts Vanquish Wraith, Ridgecrest, Aluminum lockouts CKRC Special MG946R, 208oz Torque Metal Gear Servo |
08-06-2012, 08:55 PM | #12 |
RCC Addict Join Date: Mar 2011 Location: easton
what are your thaughts on the HR links? also if you left the HR links on it would the mip drivehafts be long enough with your ax10 trans? Sent from my iPod touch using Tapatalk |
08-06-2012, 09:53 PM | #13 |
Quarry Creeper Join Date: May 2012 Location: Houston
How you liking those tires?
08-06-2012, 10:27 PM | #14 | |
Plus you can't beat the price from ckrc | |
08-06-2012, 10:30 PM | #15 |
So i picked up a 3 cell Lipo 3300mh 25c. This thing was so fast I had to put my friends SCT tires on her just to stay on the ground on pavement. |
08-06-2012, 11:10 PM | #16 |
bmhow much longer would the mips have to be for them to work? could you change the rod ends out on the HR links to the shorter axial ones? Sent from my iPod touch using Tapatalk |
08-07-2012, 03:49 AM | #17 | |
If I could find a way to allow the rear shaft to push into itself more, it would be a great help cause with all my wheel speed, you can hear it clicking. I'm done with HR thats for sure. | |
08-07-2012, 07:05 AM | #18 |
if you switched to a wraith trans it should fix the driveshaft issue, or you may be able to get a longer input or shaft. im going to be running the same trans unless i switch. Sent from my iPod touch using Tapatalk |
08-08-2012, 01:04 AM | #19 | |
I also picked up some HD diff lockers for the new axels today. | |
08-08-2012, 01:34 AM | #20 |
get a spool! even using alloy cups and axial lockers...i dont trust em' |
Ridgecrest to Wraith Conversion - Similar Threads | ||||
ridgecrest or wraith | bigred94 | Axial AX10 2nd-gen | 38 | 08-15-2012 11:18 PM |
wraith vs ridgecrest | bigred94 | Axial Wraith | 0 | 06-16-2012 09:43 AM |
Wraith/Ridgecrest C-hubs & knuckles??? | donhd04 | Newbie General | 8 | 06-10-2012 06:59 PM |
axial ridgecrest body on wraith?? | wraithchild | Axial Wraith | 2 | 02-29-2012 09:57 AM |
