07-23-2012, 10:32 AM | #1 |
| Got my VP axle shafts!! A new Hot Racing spool to go with it. These things are gorgeous. Great job VP. They *ooze* quality. It feels great to purchase something like this from a first rate American company. They are complete overkill for the 35t HH motor and 3s but the insurance they provide is priceless, anddd my Axial universals were quite literally falling apart. The new HR spool was good timing too. I was taking the axle apart last night in preparation for the parts to come in this morning when I found this I have no idea when the tabs broke off.. I didn't even notice it, I guess because it hadn't started to spin in the plastic casing yet. First time I've EVER broken even going back to my AX-10 which was very heavy. New spool is in! I like the bolts that come with it.. A little beefier than stock. VP shafts are in! It's like a dream come true. MAN, are they tight... They fit about as perfect as a mass produced product ever could. There is no end-play to speak of either.. You can push and pull all you want on the stubs and they are just perfect. Shouldn't produce any side load on the bearings though, the knuckles went on perfectly normal. Again, VP.. You guys are really on your A game right now. |
07-23-2012, 10:43 AM | #2 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| Re: Got my VP axle shafts!!
well...im jealous now!! lol those are sweet as suga' bruh' congrats on a great product |
07-23-2012, 11:28 AM | #3 |
I have really bashed my 11lb rig trying to test these shafts and all I have been able to do is bend other parts of my truck! These things are SOLID.
07-23-2012, 12:10 PM | #4 |
Harley, what are you using for grease? My first application has been of Tetra gun grease. I've always had this issue with MIPS as well.. Too little grease and they squeak, too much grease and they attract a lot of dust and dirt which basically causes it to grind itself apart...
07-23-2012, 12:22 PM | #5 | |
Quarry Creeper Join Date: Dec 2005 Location: the first state
| Re: Got my VP axle shafts!! Quote:
07-23-2012, 12:33 PM | #6 |
Great news and thanks for the pics! Great to have American company made in USA with quality too!
07-23-2012, 12:34 PM | #7 | |
The best practice I have found is to run some bearing grease at first. I ran mine like that during the first testing. After I fixed the rig I flushed the grease out best I could with WD40. Then I just shoot some WD40 in them every once in awhile to keep them cleaned out. Very little build up then. Same goes for MIP driveshafts. | |
07-23-2012, 12:46 PM | #8 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
I want a set of those!! Well when I break my stock ones..hehehe. Cool stuff VP!!
07-23-2012, 01:05 PM | #9 | |
07-23-2012, 01:53 PM | #10 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
WD40 will clean and leave a light coat of oil, but it's hard on the bearings. I'd use it sparingly. I use associated black grease, very lightly. My CVDs have always held up really well using that. Regardless if you're getting the rig wet you need to pull them apart and re-lube occasionally. |
07-23-2012, 02:04 PM | #11 |
not sure on the Wraith as its still new to me and it has only 1 test run on it but on my NSavage XL i periodically do maintenance on both diffs aswell as rebuilding the bearings. Simply pop the rubber seals out of the bearing, rinse well with wd40, DRY WELL and repack using HD grease. Put em back together and TaDah! as for the CVDs i use wd40 to clean and lube all the time! |
07-24-2012, 09:38 AM | #12 |
Rock Crawler Join Date: May 2012 Location: Washougal
I just got mine too and damn they are purdy! I wonder if they will build non-steering shafts soon? For me I use moly assembly lube like what you would put on a cam and bearings upon initial assembly. Had a tube of it and seems to stay put pretty well.
07-24-2012, 10:05 AM | #13 | |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
07-24-2012, 11:19 AM | #14 |
Yes White Lightning is very cool stuff!! I use it too on my bike and now the Wraith.
07-24-2012, 05:37 PM | #15 |
What would VP say about not using grease on these? Hard to say without burning up a set if they'll last longer greased and collecting dirt, or run mostly dry with a little flush with light oil every so often.. I've tried the bike chain lube that's supposed to dry to a waxy film.. It was a different brand though, supposedly designed by Boeing for aircraft applications, but it does NOT work as advertised... Wasted $5 on that. |
07-24-2012, 05:51 PM | #16 |
I joined the Band! Join Date: Jun 2008 Location: Sacramento
its kinda like sex, even spit is better than dry...
07-24-2012, 08:15 PM | #17 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: Got my VP axle shafts!! Last edited by ScaleFreak93; 07-25-2012 at 12:20 PM. |
Got my VP axle shafts!! - Similar Threads | ||||
Axle shafts | Squadfer | Venom Creeper | 7 | 04-19-2009 09:16 AM |
Need new axle shafts.... | eric113 | HPI Wheely King | 2 | 02-05-2008 10:05 AM |
Axle shafts | onebadtj | Tamiya TLT Crawlers | 16 | 11-09-2006 06:12 AM |
