07-30-2012, 11:13 AM | #1 |
Newbie Join Date: Jul 2012 Location: British Columbia
| Oops! Axial missed a part!
I received two Wraith RTR's the other day and when I ran them I got about 10 minutes before having major gear noise from the transmission. I opened the tranny and found that there was no shaft in the idler gear on both trucks! The idlers were just floating and rubbing on the case. Both the gears are smoked and the cases are damaged, not a good start for Axial. |
07-30-2012, 11:27 AM | #2 |
| Re: Oops! Axial missed a part!
So, why don't you send them an email and give them an opportunity to fix the issue?
07-30-2012, 12:15 PM | #3 |
Definitely worth calling Axial. No sense in wording it like that and making them look bad. We want to know the story of how the fix goes. My guess is they will have you send in the trucks and fix the trannies.
07-30-2012, 12:40 PM | #4 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
Yes for your first post that is not so nice! Axial will help because that is clearly a warranty issue.
07-30-2012, 01:09 PM | #5 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
This is the 1st I've heard of this, I think it amazing that it even worked for 10 min. missing that part, I don't see how it did. How could they leave that out, you need it to put it together. It would even be hard to get it together with that part missing.
07-30-2012, 01:28 PM | #6 |
Quarry Creeper Join Date: Mar 2009 Location: mesa
so why not call axial first and give them a chance to right the problem before bad talking them on this forum? axial has exellent customer service they solve my issues with my exo within a few days
07-30-2012, 03:11 PM | #7 |
Newbie Join Date: Mar 2012 Location: Netherlands
Uhmm, so there are bearings but no shaft on the idler gear? If I try to simulate that on my ax or scx's gearbox even with an opened gearbox there's so much play on the idler, that it will block the other gear when being rotated by the first. Are you sure the axle or shaft, is not stuck in the other half? |
07-30-2012, 03:14 PM | #8 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
my 1st wraith which i just got notlong ago was missing a bearing for my transmission. This was the "Kit". i just went and bought one from my LHS which was no biggie at all, but why are parts missing is quite annoying, and shouldnt be like this? I think Axial is slamming these out the door faster then they can assemble the kits. more attention needed Axial! |
07-30-2012, 04:50 PM | #9 |
Quarry Creeper Join Date: Jun 2012 Location: pomona
When I got my Wraith Kit it was missing one bag of parts for the diffs. I called Axial and talked to a guy named Scott (ext 4). The guy apologized and sent me the bag of parts which arrived in 2 days. He also said if I had any question or problems to give him a call. Super nice guy. They have great customer service.
07-30-2012, 05:26 PM | #10 |
Maybe I sounded a bit harsh in my post. The truth is I'm not pissed off just disappointed. I was hoping my boys could run these things right out of the box and mod them later, thus the reason to buy the RTR version. I do have brushless systems to go into them so replacing the plastic idler with a hardened steel from one my local hobby shop will be beneficial anyway. The 5mm shaft isn't in stock at my local store so I'll make a couple, and yes they were definitely not there. And the cases can be cleaned up and reused, for now. I did call Axial, they will send new parts which will arrive in "one to two weeks". They were easy to talk to, no issue sending the parts. All in all, it happens. It sucks it happened to both trucks but life goes on. My intent was not to bash Axial but rather simply vent my frustration. |
07-30-2012, 05:36 PM | #11 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
It seem's to me axial needs a bit of bashing, there customer service might be great but surely better quality control is more important. The amount of post's complaining about parts missing, falling off or breaking seams to be increasing lately.
07-30-2012, 06:42 PM | #12 |
Pebble Pounder Join Date: Jan 2012 Location: Locust Hill
It is a little strange. My Wraith, which I got in January, had a bunch of little issues like that, loose/missing screws, faulty battery connector, no grease in the tranny, etc. None of these were life-threatening, but annoying nonetheless. My Honcho which I got in April, however, has been absolutely perfect!! Not a single thing out of place or problem....go figure.
07-30-2012, 06:44 PM | #13 |
Rock Crawler Join Date: Sep 2011 Location: 5280 feet high...
These trucks have Hundreds of parts. They might miss a few. No excuses, just sayin... Axial is a good company and if you call, they will make it right.
07-30-2012, 06:50 PM | #14 |
Rock Stacker Join Date: Jan 2012 Location: Birmingham
I had the stock esc go bad. I called axial cs and had a new one in 3 days. Great customer service. Sent from my SCH-I535 using Tapatalk 2 |
07-30-2012, 06:56 PM | #15 | ||
| Re: Oops! Axial missed a part! Quote:
And I'd say it's clearly a quality control issue that should be fixed under warranty... but why? Quote:
Great Customer Service Good Product Poor Quality Control The AR60 short shaft issue should be enough for them to get it together... that's BS man. And they covered it up by installing the drive train backwards! wtf? Last edited by johnnyh66; 07-30-2012 at 07:00 PM. | ||
07-30-2012, 07:37 PM | #16 |
Pebble Pounder Join Date: Aug 2011 Location: Gresham, OR
I've built many kits over the years 5 Losi's, 1 Team Associated, 1 HPI Baja (Tons of parts), 3 Traxxas, 1 Trex, 6 E-flites, and 3 Axial's. Only the Axial, HPI, and E-flite have not had any missing parts. IMO they are one of the best company in terms of not forgetting parts. That is not to say that they don't mess up, they do. Give them a call and they will send you a new part free of charge.
07-30-2012, 07:45 PM | #17 |
but this was not a kit, it was rtr... but didn't.
07-30-2012, 11:30 PM | #18 |
this is what happens when american companies sent stuff to china to be made working at a hobby shop i see this stuff frequently thats the trade off for cheap labor
07-31-2012, 05:01 PM | #19 |
Rock Stacker Join Date: Jul 2012 Location: nor cal
ive never bought a rtr but have heard and seen soo many horror stories so i just build em myself,on a side note my wraith kit was only missing one part
08-01-2012, 12:11 AM | #20 | |
Oops! Axial missed a part! - Similar Threads | ||||
Need some help with Axial part #s | venomous98 | General Crawlers | 3 | 01-13-2011 04:57 PM |
axial part | IDnewcrwlr | Newbie General | 7 | 04-13-2009 10:34 AM |
