10-07-2012, 08:07 PM | #1 |
Rock Stacker Join Date: Jun 2012 Location: Cincinnati
| Electrotech's Wraith
Here is the newest addition to my lineup. Built the kit, parts so far: Servo: Hobbico CS-170 (stolen from my XR10 in favor of upgrading the XR10 to a Futaba S9157) RX: Futaba R203GF 3-channel (may add dig later) ESC:Castle Mamba Max Pro BEC: Castle 10A Motor: 35T Tekin Heavy Duty (Spare motor I had, I'm waiting for the Tekin 412 ROC brushless motors to come out, or I may just get the Pro4 3300kv) Wheels: Axial Rockstar 2.2 Beadlocks with R35 Ripsaws Spur Gear: Robinson Racing 87T super spur (Stock pinion so 87/20 gearing) Paint didn't come out exactly as I hoped. I masked out a silver stripe between the black and red but the masking tape sucked and the red bled under the tape so I just pulled the tape and sprayed all red. Tons of upgrades planned, just don't have deep enough pockets yet. So onto my first planned upgrade, Links, I'm thinking titanium with 4mm Revo ends, so thats either BMRC or Vanquish. Can't go wrong with either? Couple shots in the basement build area. |
10-09-2012, 09:21 AM | #2 |
| Re: Electrotech's Wraith
First run out I ate up the front diff gears. Lucky the LHS had a set of the HD bevel diff gears. I installed the HD gears and flipped the lower link mounts around to lower it down some.
10-13-2012, 04:22 PM | #3 |
First upgrade Vanquish Drag and steering link. I had a problem getting the steering link to fit. It was hitting the diff cover and not allowing full steering. I mounted everything the way it's shown on Vanquishes website and it just doesn't clear the diff cover. I was playing around with the mounting and found a solution that I am quite pleased with. I mounted the steering link on top of the knuckles and the drag link below the steering on the right side so the steering link rides behind the servo horn and above the diff. With this set-up now the limiting factor in the steering is hitting the lower links and of course I don't think the universals can go much further. Added benefit it's all up higher and more clearance now. |
10-13-2012, 09:06 PM | #4 |
Quarry Creeper Join Date: Jan 2012 Location: Okanagan Falls B.C.
Well done on the steering!! That's a great idea. I have the vanquish steering as well and ground down the diff cover to free the steering issue but I gotta say I like your fix much more. I'll have to take a look at doing the same. |
11-07-2012, 11:11 AM | #5 |
I've added a few mods and haven't updated in a while. She now has a MMP pushing a Pro4 3300kV, MIP driveshafts, Robinson Racing trans gears, Vanquish Lockers, Vanquish Links, and Axial HD gears front and underdrive HD gears out back. Steering upgraded to Vanquish CMS and Panhard link. Anyways, I'm now getting slippage and grinding from the stock ratio Front HD hardened diff gears. I need to replace the gears and was thinking about going with the overdrive gears in the front. I have underdrive in the back and with the Pro4 just wondering if I shouldn't change the ratio that much. |
11-24-2012, 11:05 PM | #6 |
Got a goodie box today, RPP rocks, after I ordered 11 minutes got shipping info on my door 3 days later from Cali to Ohio, and one of those days was Thanksgiving. Front Axle built! Transmission is underway, still waiting on supershafty 6mm outputs and 6mm Revo MIP Hubs to finish the trans. I was going to go Vanquish Trans housing but I'm going to try the AX10 plastic housing for a while for the COG savings and see how it holds up. |
11-25-2012, 07:11 AM | #7 |
Newbie Join Date: Sep 2012 Location: In a House
Man that thing looks sweet, I'm diggin the front end. How do you like the poison spyder covers?
11-25-2012, 08:48 AM | #8 |
Covers are nice, good machine work. They match the profile of the low profile axial covers so pretty good on clearance. I'ge only done the front so far. When I get to the rear it will tell the tale with the larger under drive bevel gear, should still fit though.
11-30-2012, 07:16 AM | #9 |
Got the trans put together last night. Axial HD motor plate, all RR hardened gears, GearScience Gear Jelly, supershafty 6mm outputs, and 6mm Revo MIP hubs. Spur is a 32p 56t Duratrax Evader Spur, and Axial 12t pinion for the 5mm output shaft of the Pro4. |
12-15-2012, 06:42 PM | #10 |
Got the rest of the build done. Rear axle completed, wheels and tires, and a few other odds and ends. So as it sits right now I'm finished upgrading and will only go further if I break something. Hopefully I built it enough to survive the power of the Pro4 and the only thing I have concerns with are the axial universals, may need to get the vanquish VVDs. Completed Parts list: Tekin Pro4 3300kV Mamba Max Pro Castle BEC Futaba S9157 Axial HD Motor Plate VP AX10 Trans Case 32p Spur/Pinion 56/12 Robinson Racing Idler and Diff gears Super Shafty 6mm Outputs MIP Drive Shafts w 6mm Revo ends on trans Axial HD front and Under drive rear bevel gears VP Lockers STRC Bearing Caps Axial Universals VP Axle Housings RC4WD Poison Spider Diff Covers VP Link Mounts VP Axle Trusses VP Knuckles, C-Hubs, and Lockouts VP 1/4" Titanium lower Links VP 3/16" Titanium Upper Links VP Steering and drag links VP CMS and Panhard Blue Monkey Knuckle Weights VP SLW v3 1" wheels RC4WD Irok 2.2 tires Pro-Line PowerStroke Slash Shocks |
12-15-2012, 08:55 PM | #11 |
Pebble Pounder Join Date: Jul 2011 Location: NorCal
Sick rig. Im diggin the paint! |
12-16-2012, 02:54 PM | #12 |
Got to play around a little today. Wraith hill climb - YouTube And my friends wraith playing on same hill Wraith hill climb - YouTube |
Electrotech's Wraith - Similar Threads | ||||
ElectroTech's XR10 Build | ElectroTech | Axial XR10 | 16 | 08-12-2012 10:58 AM |
