11-20-2012, 06:47 PM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: Denver
| battery, esc and Rx up front ?
is it possible to put everything up front ? the battery, ESC and the reciever, looks very tight if, its even possible. |
11-20-2012, 07:53 PM | #2 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
| Re: battery, esc and Rx up front ?
I have everything mounted up front and also have a chassis mounted servo up there too. I can fit up to a 3s 2600 battery. I run a standard spectrum rx and a tekin rspro esc so no small electronics. Its tight but it all fits. I use an aluminum plate i found on ebay and i trimmed some of the interior as well as cut all the wiring to exact lengths to save space and clean it up
11-20-2012, 08:02 PM | #3 |
Very nice, do you happen to have any pictures?
11-20-2012, 08:36 PM | #4 |
I have a build thread on here with a couple crappy pics
11-20-2012, 09:03 PM | #5 |
Rock Stacker Join Date: Oct 2008 Location: St Louis
| Re: battery, esc and Rx up front ? |
11-20-2012, 09:28 PM | #6 |
jetbuilder, thats nice, i dont see the rx box that mine has. |
11-21-2012, 08:25 AM | #7 |
Rock Stacker Join Date: Nov 2011 Location: NEPA
I had mine set up like that for a while, but I like to tinker to much and servicing things became impossible. I ended up giving up on the scale look and just stuck the ESC in the passenger seat. Perfect.
11-21-2012, 08:31 AM | #8 |
Quarry Creeper Join Date: Jul 2012 Location: Alpharetta, GA
I have all kinds of junk under my hood. -4000Mah 3s Lipo -Holmes BR-XL / Axial AE-2 Have both been there at one point. -Futaba R204GF-E Receiver -CC BEC -Cheap HobbyKing BEC running the lights -HeyOK Switch -All the plugs for all the lights! I put my ESC between the shock towers and made a Lexan shelf for the RX to sit right above it. It's tight but if you take your time you can make a bunch of stuff fit. |
11-21-2012, 08:58 PM | #9 |
Pebble Pounder Join Date: Nov 2009 Location: New Bern
It is possible it all depends on the size of the battery though. I have just compacted mine to save room for a servo winch if I need it, but there is room to mount the RX up front also. This is on my scaleready chassis but space is very similar to stock wraith chassis. Pic of RX8 and Turnigy nanotech 2200mah mounted behind the dash with inner fenders installed. |
11-22-2012, 01:08 PM | #10 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Re: battery, esc and Rx up front ? stock esc bec 1300 mah 2s rx & connectors for servo/bec in ballon light controller in yellow ball thingy all on a plastic plate mounted to rx/esc plate |
11-22-2012, 01:29 PM | #11 |
thanks for the pix all, please keep them coming |
11-22-2012, 02:00 PM | #12 |
RCC Addict Join Date: May 2008 Location: Southern,WV
Mines a bit different.My ESC is all the way to the driver side up and under the dash at the drivers feet.I didn't cut any of the interior out or anything. Let me know if you'd like to see any different angles or any thing. |
battery, esc and Rx up front ? - Similar Threads | ||||
Battery up front I looked | moto261 | Axial Wraith | 5 | 12-02-2011 04:16 PM |
Front battery access | Supercomputer5 | Axial Wraith | 6 | 08-17-2011 07:19 PM |
What Battery For Use With Front Servo/Battery Plate? | Shanty | Axial AX-10 Scorpion | 23 | 08-13-2009 03:05 PM |
Does this mount the battery in the front ? | RazBarlow | HPI Wheely King | 1 | 05-16-2009 11:53 AM |
Wk battery up front | 8upboyz | HPI Wheely King | 14 | 05-08-2009 01:46 PM |
