12-06-2012, 06:38 AM | #1 |
Newbie Join Date: Feb 2012 Location: England
| What wraith spares?
I'll hopefully be getting my wraith soon and was wondering what spares I need to be carrying, it'll be running 21t brushed. Thanks
12-06-2012, 07:55 AM | #2 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: What wraith spares?
Bearings. LOL |
12-06-2012, 08:43 AM | #3 |
lol how did you manage that?
12-06-2012, 11:35 AM | #4 |
Newbie Join Date: Oct 2011 Location: Grande Prairie
are you upgrading any thing off the batt? is it the kit or RTR?
12-06-2012, 11:53 AM | #5 |
| Re: What wraith spares? Torque! MuuuuWhoooHaaaHaaHaa!!!! Tranny is geared down with Robinson Racing gears. Axles are geared down in the front and up in the rear (known as over/under drive), and I'm running a Holmes Hobbies 45T Torquemaster Pro. Add all that up, and 'test' it out on the carpet with some de-lugged 2.2 RC4WD Rock Crushers (take out every other outter lug on both sides in parallel, then take out every other set of center lugs in parallel offset from the outer lugs - provides a VERY good amount of grip) mounted to a good set of beadlocks, and you have a great recipe for broken bearings. I'm pretty sure that I'm going to twist the stock drive shafts sooner than later. It's got so much torque that if I get a rear wheel jammed in a rock, it'll flip the whole rig over. I found that out on accident. LOL Oh... I almost forgot. It's powered with a 25c 5000mAh 3S battery. Buy it, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger, break it, build it stronger..... you get the idea. Last edited by TheScaleAddict; 12-06-2012 at 11:56 AM. |
12-06-2012, 01:10 PM | #6 |
| Re: What wraith spares? |
12-06-2012, 01:38 PM | #7 | |
| Re: What wraith spares? Quote:
12-06-2012, 01:42 PM | #8 |
I wanna be Dave Join Date: Jun 2006 Location: Ukiah
Make sure you get some spare C hubs and Knuckles, aluminum would be best. These seem to be most common parts we see to break initially. If you have spares in your parts box you can keep on playing. Have fun with your build |
12-06-2012, 03:18 PM | #9 |
| Re: What wraith spares? And threadlock! If you get aluminum housings and use the aluminum c-hubs/knuckles, the bolts will rattle right on out...
12-06-2012, 04:35 PM | #10 |
I run a 27T HH Torquemaster Pro on 3s almost exclusively and my whole drive train is hardened steel, except for the spur.. I tend to have a lot of finesse with my driving and I don't like to abuse my $1000+ *toy* so I don't beat it too hard.. Having said that, all I carry for spare anything is a spur gear, and a couple hood pins. Oh! And axle pins and wheel nuts.. If you want to have a completely redundant backup plan for when you're a mile from the truck.. I'd probably want some plastic knuckles, chubs, lockouts...And hardware to go with it.. If you have a lot of wheel speed a few bearings might not be a bad idea.. But for mine that tops out at about 8mph they rarely if ever fail to the point that I can't drive it back. You could even carry a spare motor but unless you never inspect it and it burns out on you in the field or you run through a bunch of mud and water and chew it all to hell, I wouldn't want to carry the extra weight around. Last edited by Jus; 12-06-2012 at 04:37 PM. |
12-06-2012, 05:22 PM | #11 | |
Newbie Join Date: Jun 2012 Location: Salem, WV
Hi For spares I would keep wheel nuts, bearings and a set of the pins that go into the drive shafts, (AXA175 Screw Shaft M3x2.5x11mm) the first thing i broke ! Cephas do you think the HH 35T HH Torquemaster Sport 450 has the same top end as the stock 20 T wraith motor ? I am looking for a motor that will give me the same top speed as stock but more torque for crawling I do realize that I will have to change my gearing and do some other upgrades that go along with a different motor. I currently run a 2S LIPO on the stock setup with the battery upfront. Thanks Scott | |
12-06-2012, 07:24 PM | #12 | |
I wouldn't think so, since it has more turns. More turns = higher torque & lower speed. Less turns = higher speed & lower torque. It would be faster than mine. They have a 27T too. If you want to keep the speed, that may be a better route for you to go. Last edited by TheScaleAddict; 12-06-2012 at 07:27 PM. | |
12-06-2012, 08:08 PM | #13 | |
12-06-2012, 11:14 PM | #14 | |
Pebble Pounder Join Date: Feb 2009 Location: New York
Note to self - buy some more spare parts... Now I'm sleeping at the mailbox waiting in anticipation! | |
12-06-2012, 11:43 PM | #15 |
12-07-2012, 01:36 AM | #16 |
Rock Stacker Join Date: Oct 2010 Location: Birmingham
12-07-2012, 08:20 AM | #17 |
first thing I broke was a Chub, then knuckle, then lower link (rtr) then front upper shock mount
12-07-2012, 09:06 AM | #18 | |
It crawls really well. The CrawlMaster Pro 540 has a 5 slot armature which gives really good low end control. A 13T 5 slot motor is about the same speed as 27T 3 slot motor. You have to compare Kv instead of turns for motors with different number of slots in the armature. The rest of the setup: BR-XL 54T/10T 32P Kimbrough 54t 32p Spur Gear #129 RRP Pinion 10t 32p #0100 Last edited by k7zpj; 01-10-2013 at 05:06 PM. | |
12-07-2012, 06:03 PM | #19 | |
12-07-2012, 09:30 PM | #20 | |
I stripped out the spur gear so I upgraded to 54/10 32P. The part numbers were in my previous post. Last edited by k7zpj; 01-10-2013 at 05:07 PM. | |
What wraith spares? - Similar Threads | ||||
What do you keep for spares? | AC-130 | Team Losi Comp Crawler | 16 | 10-31-2009 11:44 PM |
What Spares | ede670 | Tamiya TLT Crawlers | 4 | 01-11-2007 05:35 PM |
