12-14-2012, 02:49 PM | #1 |
Rock Stacker Join Date: Dec 2012 Location: marion
| what gear ratio with brushless and 2 speed
Ok first off thanks for the forum guys , ii haven't even received my kit yet and I'm planning on doing a tekin 3300 brushless with mama max pro speed controller and a bulletproof 2 speed all metal gears ,I'm going with 32 pitch so what spur and opinion do in need , I read Harley guide but not sure if it retained to the 2 speed ax10 granny also
12-14-2012, 03:56 PM | #2 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: what gear ratio with brushless and 2 speed
I don't think it matters what trans you run but a 4:1 is always standard I think. So run 56T Spur 14T pinion. 32P I would do that but maybe someone else can chime in too. |
12-15-2012, 07:53 PM | #3 |
Newbie Join Date: Dec 2011 Location: Falling Waters,WV
I'm building up mine with the traxxas vxl system. So far went with harden gears on the stock transmission and replaced the 3 pc output shafts. With a solid one .works good so far. |
what gear ratio with brushless and 2 speed - Similar Threads | ||||
gear ratio vs gear size | johnnyh66 | General Crawlers | 13 | 07-17-2012 09:55 PM |
gear ratio | kortt | Axial AX-10 Scorpion | 9 | 10-14-2009 07:26 AM |
gear ratio is gear ratio w/trans? | swell searcher | General Crawlers | 4 | 08-16-2008 01:56 PM |
gear ratio | nuts5000 | Axial AX-10 Scorpion | 0 | 02-03-2008 08:40 AM |
