12-16-2012, 02:41 PM | #1 |
Pebble Pounder Join Date: Feb 2012 Location: Riverside
| Steering knuckle screws......URGH
Ok, so I have been enjoying my RTR wraith. Now for 2 weeks and have lost the screws that thread into the axle for the steering knuckle a half dozen time..... Anyway she'd some light as to why, and a fix? |
12-16-2012, 02:48 PM | #2 |
| Re: Steering knuckle screws......URGH
replace the old screws with 3mm fine thread screws
12-16-2012, 03:57 PM | #3 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
Yes or if you have CA glue try that on them or the combo!!
12-16-2012, 04:30 PM | #4 |
| Re: Steering knuckle screws......URGH If the holes aren't too badly stripped out just doing that will fix your problem.. Otherwise some CA glue *and* the 3mm fine thread should do it. Coarse thread has no business being used for applications such as this but Axial doesn't seem to get it. |
12-16-2012, 05:34 PM | #5 |
Newbie Join Date: Jun 2012 Location: Salem, WV
Hi I had the same problem with the scews stripping out. I finally ended up going with the axail aluminum knucles and chubs Axial Aluminum Steering Knuckle Set (Black) (2) [AXI30760] | RC Cars & Trucks - A Main Hobbies Axial Aluminum C-Hub Carrier Set (Black) (2) [AXI30762] | RC Cars & Trucks - A Main Hobbies Suprisingly the coarse thread screws 3mm from AXIAL are backing out of my aluminum pieces. Guess I have learned the heard way will have to put in fine thread srcews Thanks Scott |
12-16-2012, 07:27 PM | #6 |
| Re: Steering knuckle screws......URGH Why would you ever put coarse thread in a fine thread hole!! You basically stripped that thread!!
12-16-2012, 07:54 PM | #7 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
| Re: Steering knuckle screws......URGH Buy a set of Beef Tubes and use some fine thread bolts, Loctite them and you're done
12-16-2012, 08:42 PM | #8 |
Where do you buy beef tubes??
12-16-2012, 09:00 PM | #9 |
Newbie Join Date: Nov 2012 Location: SoCal
| Re: Steering knuckle screws......URGH |
12-16-2012, 09:13 PM | #10 | |
| Re: Steering knuckle screws......URGH Quote:
Because those are the screws that axial sent me.with the aluminun knuckles to use They never specified or reccomended ti use a different type of screw with there product, so i didnt know.any different. The chubs will end up being replaced one way or another. scott | |
12-16-2012, 09:41 PM | #11 |
12-17-2012, 06:09 AM | #12 |
01-25-2013, 09:16 PM | #13 |
Newbie Join Date: Mar 2005 Location: riverdale
I use lock tight paste
Steering knuckle screws......URGH - Similar Threads | ||||
Alum CHub and Knuckle screws ? | juswin24 | Axial SCX-10 | 7 | 06-21-2012 02:33 PM |
Keeping knuckle screws in. | The Violator | RC4WD Bully | 55 | 02-05-2010 03:40 PM |
TLT Knuckle Screws | lrdraca90 | Newbie General | 1 | 03-11-2008 07:14 PM |
Knuckle screws | Evil-Jay | Tamiya Txt-1 and Juggernaut | 3 | 04-12-2005 03:58 PM |
