01-03-2013, 07:01 PM | #1 |
Newbie Join Date: Apr 2012 Location: lake stevens
| rtr wraith?
I have a new rtr wraith and its faster in reverse the forward. My throttle switch is in the normal position and when you pull the trigger to go forward it does and the esc light is green. Will flipping my gears still fix the issue or? Thanks |
01-03-2013, 07:23 PM | #2 |
| Re: rtr wraith?
i dont think flipping your gears will fix it but im not positi ve what you mean by that.
01-03-2013, 07:35 PM | #3 | |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
| Re: rtr wraith? Quote:
That's a really odd issue. You might want to troubleshoot a bit more and see if there is another issue needing your attention. | |
01-03-2013, 07:48 PM | #4 |
| Re: rtr wraith?
doesnt the rtr have castle controler? ive have my controler set up for 100% power in forward and 50% power in reverse. switching gears seems ass backwords and how do you even switch the gear positions? |
01-03-2013, 07:54 PM | #5 |
| Re: rtr wraith?
I think from what i have read when i searched (wraith is faster in reverse) some of the posts said to flip the diffs. None of the posts i found were having the same issue when the remote th switch was set to nomal and the esc lights turned green when you go forward and red for reverse. I APPRECIATE your help a ton. Could it just be the motor going bad already?
01-03-2013, 08:58 PM | #6 |
Quarry Creeper Join Date: Oct 2011 Location: Shirley
| Re: rtr wraith?
i think i ended up flipping my diffs, then switched my motor wires so the esc was right. (green forward, red reverse) mine was already running a different motor from original, with mismatched wires though so i dont remember if there was a speed difference or not. i wouldnt have known about the diff issue except i just happened to read about it in a thread. checked mine, found them wrong and just went ahead and made it right.
01-03-2013, 09:01 PM | #7 | |
correct me if im wrong but im pretty sure the stock gears are straight cut, not helical. so same strength either direction. | |
01-03-2013, 09:11 PM | #8 |
Right. Not sure about aftermarket gears though. ...just thinking 'out Loud'. |
01-03-2013, 09:15 PM | #9 |
| Re: rtr wraith? I checked out my esc and noticed that the green light was blinking while full throttle so I recalibrated the esc and it fixed it. Thanks so much to everyone help. Im pretty new here. I try to read before I ask a dumb question. Didnt work this time lol. Thanks again |
