01-08-2013, 08:15 AM | #1 |
I wanna be Dave Join Date: Feb 2007 Location: BFE, NV
| Quick Question 4s
Anyone run a Pro4 3300 on 4s? If so what gearing and how were your motor temps? Thanks!! |
01-08-2013, 10:07 AM | #2 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
| Re: Quick Question 4s
I hope you plan on buying a helmet and lots of Kevlar.. I've seen a pro4 4000, in a Wraith, on 3s and it was scary to say the least.. Think about it this way. 4000 X 12.5 (3S) = 50,000 RPM (No Load) 3300 X 16.8 (4S) = 55,440 RPM (No Load) Only about a 10% increase in RPM, with a LOT more cost... And according to the Tekin site, it says the 4000 is only rated to 2s, so 4s may equal meltdown... |
01-08-2013, 10:10 AM | #3 |
| Re: Quick Question 4s |
01-08-2013, 12:22 PM | #4 |
RCC Addict Join Date: Dec 2007 Location: Rochester Hills
01-08-2013, 02:26 PM | #5 | |
| Re: Quick Question 4s Quote:
Ill start with 11/60 and check temps. Im running 2 5300mah packs wired for 14.8 volts for hauling ass or wired for 10,600 mah for trail duty.. | |
01-08-2013, 04:00 PM | #6 |
14.8v? 3.52 S ?? What combination are you using to make 14.8 volts? |
01-08-2013, 05:10 PM | #7 |
01-08-2013, 07:11 PM | #8 |
Newbie Join Date: Jan 2012 Location: Kamloops
01-08-2013, 08:07 PM | #9 |
Not if it is LiPo.... Lipo cells are charged to 4.2 cells each. If he is running Ni-Cad or NimH then the 7.4 still isn't right, because it would be 7.2 volts per pack... 2s packs will be about 8.4 volts 3s packs will be about 12.6 volts |
01-08-2013, 08:26 PM | #10 |
| Re: Quick Question 4s It says 7.4 volts right on the battery. I have no idea how the manufacturer arrived at that number and I don't really care.. As far as that goes I doubt they will charge to exactly 5300mah either.. |
01-09-2013, 07:49 AM | #11 |
| Re: Quick Question 4s The max volts they charge to and the voltage they run at are two different things. As stated, rated at 3.7v/cell: 7.4v 2s, 11.1 3s, 14.8 4s
Quick Question 4s - Similar Threads | ||||
Quick question??!? | unknownhero55 | HPI Wheely King | 2 | 05-04-2012 09:44 PM |
California Gun owners. Quick question, need a quick answer. | Szczerba | Chit Chat | 8 | 11-23-2010 12:35 AM |
quick question | Left_Rear_Nut | Axial AX-10 Scorpion | 2 | 01-06-2010 04:14 PM |
Quick Question... asking for quick answer.. | JeeperoManiako | Electronics | 0 | 10-13-2006 06:47 PM |
quick question. | airranger | Newbie General | 7 | 08-16-2006 08:53 PM |
