01-10-2013, 06:50 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
| using nimh/lipo ???
Just picked up a used, stock Wraith. Needed one part to complete. Should be here tomorrow. Hobby King messed up my Lipo order so i'll be using a couple Nimh's I have. The guy I bought it from said the ESC needs to be programmed to use lipo or Nimh. And that its currently setup for Lipo. I just read through the manual and didn't see anything about this. Do I need to do something special to this stock setup? This is my first Crawler and I'm excited as shit to drive this ASAP. I want to cover all my bases for a smooth "first start". |
01-10-2013, 07:12 PM | #2 |
| Re: using nimh/lipo ???
shouldnt matter as long as the voltage is comparable. i have know idea how that esc is set up |
01-11-2013, 08:26 AM | #3 |
About to start putting this together. Id like confirmation that I don't need to do anything to run nimh vs lipo.
01-11-2013, 09:43 AM | #4 |
Quarry Creeper Join Date: Jan 2012 Location: My house
Depends on certain ESC brands. Some of them automatically detect that you are using the NiMH and when you use a lipo. Other you have to press the programming button in for a few seconds and a beep normally tells you you've switch modes. While higher end ESCs you have to manually input using a program card or software or just the blinking lights on the esc to program it. What esc do you have??
01-11-2013, 11:00 AM | #5 |
I wanna be Dave Join Date: Jan 2012 Location: CANADA
| Re: using nimh/lipo ??? |
01-11-2013, 12:28 PM | #6 |
There u go all you have to buy is the castle link and download the software. From there you can set up the different modes.
01-11-2013, 01:09 PM | #7 |
Its a stock ESC. I read the above link in the manual. Appears theres no difference between the 2 batteries. I've already connected all electronics with the Nimh. Everything works now. Guy also sold me a bunk servo and some mismatched parts. Who knows what he was talking about....
01-11-2013, 02:20 PM | #8 |
Youl want to at least set the lvc so you don't ruin the lipo. I run my low voltage cut off at 3.5. There's a ton for f adjudtments you can make with the castle link |
using nimh/lipo ??? - Similar Threads | ||||
lipo vs NiMH | nylint pimp | Redcat Crawlers | 13 | 06-01-2010 07:11 PM |
Lipo VS Nimh | Tortuga275 | Electronics | 6 | 01-06-2010 06:00 AM |
lipo vs nimh | jwilli2213 | Electronics | 6 | 04-25-2009 05:27 AM |
Lipo or Nimh | kurt | Electronics | 5 | 11-17-2007 08:15 PM |
Lipo/Nimh: What to do? | SpyderMonkee | Electronics | 13 | 09-22-2007 08:52 PM |
