Thread: New Brite JK Wraith
Old 01-10-2013, 10:04 PM   #1
5th D Owner/Driver
cboggs's Avatar
Default New Brite JK Wraith
Had this body laying around and got some inspiration from ScaleReady's 2.2 build. This is a perfect fit onto the wraith chassis using the same body panel screws on the side to mount it up. Its still a full wraith chassis under the body, just need to cut the rest of the cage off and build a new top half of the cage to better match the body. Still need to finish the body sanding and then paint. More updates soon.
cboggs is offline   Reply With Quote
Old 01-10-2013, 10:06 PM   #2
Default Re: New Brite JK Wraith
looks sweet ima need to do this to mine now lol
kakachille is offline   Reply With Quote
Old 01-10-2013, 10:21 PM   #3
Instant full internal cage. I like.
TheScaleAddict is offline   Reply With Quote
Old 01-10-2013, 10:23 PM   #4
Looks like a wrangle on 1 tons. Sweet
meinthe73 is offline   Reply With Quote
Old 01-10-2013, 10:39 PM   #5
Great stuff dude,
I didn’t realize you get bodies that will fit over a full wraith cage...?
Can you or anyone please point me in the right direction as to what to look for?
Thanx and looking forward to see how your rig turns out.
Charel is offline   Reply With Quote
Old 01-10-2013, 11:07 PM   #6
5th D Owner/Driver
cboggs's Avatar
Originally Posted by Charel View Post
Great stuff dude,
Check the classified section as sometimes you can find the NewBrite JK bodies there or post up in the wanted section. Dont know for sure if these are still in Walmart stores anymore as I bought this one awhile ago.
Old 01-11-2013, 01:40 AM   #7
Old 01-11-2013, 06:08 AM   #8
Or 3/4 tons... One tons rock Dana 70's. Well, some of them do anyway. :P
Old 01-11-2013, 06:26 AM   #9
You will find once you chop the wraith top tube work off the interior will fit perfect.
You can also with a little dremel work get the two lower front grill mounts to fit threw the grill.
sally1800 is offline   Reply With Quote
Old 01-11-2013, 06:30 AM   #10
I thought about doing this, looks like I know what I'm doing when I get outta work
Bogncrawl is offline   Reply With Quote
Old 01-18-2013, 08:59 PM   #11
5th D Owner/Driver
cboggs's Avatar
Got some Krylon lime green paint on it today, looks just like the gecko green found on the new jk's. Also cut off the rest of the stock cage and added a dingo cage.
Old 01-18-2013, 09:32 PM   #12
was cutting the cage on the Wraith an absolute must? Thanks
Old 01-18-2013, 09:39 PM   #13
That looks cool. How bout some pics without the body. I'd like to see the cage work you did.
powercat is offline   Reply With Quote
Old 01-18-2013, 09:49 PM   #14
5th D Owner/Driver
cboggs's Avatar
Body will fit fine with the stock cage but I had mine already chopped up from a previous build. I also think the dingo cage follows the lines of the body a little better. It is screwed through the dash bar and you can see in the rear shots how it is screwed and spaced up. I'll get some pics up soon.
Old 01-18-2013, 10:09 PM   #15
thing looks super bada$$ nice job
Old 01-19-2013, 08:10 AM   #16
looks good. im digging the paint
heavy87 is offline   Reply With Quote
New Brite JK Wraith - Similar Threads
My take on a new brite jk spyderwebbcustoms 2.2 Scale Rigs 62 10-20-2011 08:43 PM
New Brite Bodies HotRod2507 Paint and Body 8 07-19-2010 11:34 AM
New brite Jk paint help edge540 Paint and Body 8 01-28-2010 09:00 PM
new brite BlazinKreeper Arizona 3 10-15-2008 09:03 PM
